How To 4.2 V6 Swap
Orange 94
Alberta Canada
I wanted to add a how to 4.2 v6 swap and split port swap.
Here is a quick basic guide.
Early 97-98 4.2s had a 2-pc main girdle that connected the 1st to the 2nd main cap and the 3rd to the 4th main cap and had larger main bolts. Mid-1998 and up 4.2s used a 1-pc girdle that only connected the rear 3 main caps and had smaller main bolts.
To use the early 4.2 in any Mustang will require replacing the girdle with a newer 3 main style from a 4.2, a 99-up 3.8 girdle or just delete it. You will also have to cut the girdle studs sticking out of the head of the main bolts on the 1st main bearing. The 99-00 3.8s used a factory windage tray/girdle that is better than nothing but certainly not ideal. The 01-up 3.8s use the same windage tray/girdle as the 4.2.
Late 00 3.8s are actually early 01 spec engines that are internally balanced. If you have one of these.....just use the notes for an 01-up.
Edit by 97Stallion: here's some extra info. 97-98 4.2L engine are directly compatible with 94-98 3.8 crank pulleys. So if you have a 97-98 4.2 crank and balancer, you can use your 3.8 crank pulley/underdrive pulley.
94-98 Single port heads
- 4.2 shortblock
- Single port heads/fuel rail/intake
- Mustang 3.8 water pump
- Auto trans = 4.2 or 01-up flexplate
- 5spd = 01-up or rebalanced 3.8 (0 or neutral) flywheel and a pilot bearing
- V6 Mustang bellhousing
- Re-use your stock cam position sensor
- 01-up 3.8 oil pan
- 01-up 3.8 oil pick-up tube and screen
- 4.2 damper or 01-up 3.8 damper (use the 01 pulley for blower cars)
- Re-use the stock 3.8 oil pressure sender and tube
- Re-use the Mustang headers
- You can use the 4.2 or 3.8 dipstick. Just keep track of where 5 qts puts the mark when refilling with oil.
94-98 Split port heads
*** You will need to perform all the mods required for a split port conversion plus these steps for the 4.2 (see pbmilan or V6sprout for the video) ***
- 4.2 shortblock or longblock
- You can use the 4.2 heads
- Mustang upper and lower intake
- Custom return style fuel rail (VMP has them)
- 01-up 3.8 oil pan
99-00 split port heads
- Mustang upper and lower intake and fuel rail
- 01-up 3.8 oil pan
01-up split port heads
- Auto trans = your stock flexplate
- 5spd = your stock flywheel and a pilot bearing
- Your 01-up 3.8 oil pan
- Your 01-up 3.8 oil pick-up tube and screen
- Your stock 01-up 3.8 damper
This guide is similar to the one I followed. It is from another forum, click here.
Even though the guide is fairly complete, I'd like to add a few things;
1.You do NOT need a 01-up 3.8 oil pan for the swap.
You can use an earlier oilpan and simply cut off 2 studs (this does not cause any problems or weaken anything.)
I made a how to below
Contrary to popular belief it is possible to make a oil pan work for 4.2 v6 swap with very minor modification.
What you need:
3.8 v6 oil pan
Modifications:
Cut 2 Studs
Bend a bracket
In my 4.2 v6 swap I used a 3.8 v6 oil pan, even though many people claim you can't. While having the engine completely apart we noticed there was only two studs preventing the oil pan from bolting on. The oil pick up tube also needs to be bent a little as well.
The oil pan I used is from a 1994 3.8 v6 Mustang. I am unsure if there are any changes in oil pans as the years progressed, I cant imagine there is though. If someone could confirm a difference that would be great.
Step 1
Trim the two front studs so it looked like the picture below
Step 2
Bent the oil pick up tube so it looks like pictured below.
You will have to play around with it a little until you are happy with the location
Now the pan should fit on without any problems
I've been driving my car for years now without any oil problems.
Hope this helps anyone doing some research or anyone facing the problem.
2. You will need to do some custom work to the heating tubing.
3. You will need to do some custom work for the fuel rail.
4. You need to hold open the IMRC or remove and plug the holes.
I removed the IMRC and plugged the holes.
5. There is an extra temperature sensor the Mustang uses.
You will simply need to drill and tap a hole for the extra sensor in the intake.
6. 94/95 or 94-98 (can't remember which) the stock mustang headers are the best (obviously long tubes would be better)
7. Use as much of the Mustang 3.8 parts as you can.
Maf, injectors,upper intake(or windstar conversion)...
8. You can try to get away without a tune. Its recommend you do get it tuned though.
9. Emission controls are an issue (EGR).
If you don't have to do emission tests, I recommend just removing all of it.
10. Play will connectors and sensors (again, use as much mustang as possible)
11. K member.
(side note)
The v8 and the v6 members are the same for the same year. But you need the correct motor mounts. If you have 94/95 k member use the 94/95 v6 mounts, if you have 96/97/98 k member use the 96/97/98 v6 mounts and so on.
I think that's basically all. I'll update if anyone has corrections or if anything else comes to mind!
Happy v6ing!
StoicPanaphobic
My only question is, how do I tune it without a dyno? There's no dynos in my area, and I can't find a compatible handheld.
Orange 94
Orange 94
Alberta Canada
I would contact VMP about remote tuning (email tuning).
Like I said, remoting tuning should do the trick for a mild N/A setup. I strongly recommend if you go with boost to but it on the dyno.
What do you mean you can't find a compatible handheld? VMP sells the handheld SCT tuner you will need for their tunes.
racenmotorsports
Kingsland GA
thanks for this. I may be getting the motor to do this soon. I got junkyard wars going on here. Last time I was at each of them I was scoping out the good engine to pick.
baddbradd
Found a COMPLETE 04 4.2 at my buddies j.y., has a rod knocking. I'm gonna pull the pan this week and check it out. How much u say?? $100 !!!!!!
Jubert
which vehicle year and model should i pull my 4.2 from, for the 98 v6 mustang ?
96blak54
In the shop
With what little research ive done and my experience from a 98 E150 4.2l....most of the bugs got worked out by 2002 and is a definite year in the clear for reliability
g36 monkey
Orlando, Fl
f-150, e-150, the newer the better is how I look at it. If you're trying to just swap one in, I would definitely change the head gaskets before dropping it in (while the motor is out, much easier) and if you're that far into it, may as well port the heads and intakes.....o wait. sounds like my buid haha.
Canaryonvskf’s
