How to Get Weld Wheels to fit without spacer
MustangMatt96GT
Many people know that Weld racing Prostars or Draglites have a problem clearing the front brakes. Infact many drag wheels do that are skinny. Anyway i ran a spacer for about 6 months. I got sick and tired of it. Not to mention with the long shank lug nuts that the wheels require, the spacer then eats up about 3/8s of the threads. The more threads the better, and its a NHRA rule for the lug stud to come through at least half the nut part of the shank Lugs. Thus the reason I have 3 inch studs in the rears and i am in the process of putting the 3 inchers in the front too.
1. Jack up car and secure the car on jack stands. Take front wheels off.
2. Once wheels are off, you are all set to go at it. Go grab you hack saw. Start cutting off the bar that goes in front of the rotor.
3. Once the bar has been cut off, you now have to get an angle grinder and start grinding at the ends of the caliper bracket. You have to take quite a bit off.
4. Keep grinding off metal until you can get your wheel on there with out any rubbing. I took mine down quite a ways.
5. Once you have it so it can clear. Take some Hitemp paint and paint them the color you want. This makes it so they wont rust.
6. Put the wheels back on and lower the car. Now take it for a drive to make sure with the extra weight of the car, there isnt any rubbing.
Here is a picture of mine off of the car, because of the stud change.
Here it is on the other side on the car.
and here is the length difference between the stock lug studs and the ARP 3 inchers.
scarface
Guest
I did the same. Ran it like that for a year with no issues. Truuble did the same, if he was still with us he would tell you of his 9 second passes like that. The spacer makes it look terrible.
MustangMatt96GT
I also had to grind off part on the caliper. Ill take a picture later...
MustangMatt96GT
Stock Caliper on drivers
Ground Caliper on the passenger side
With it all finished up and painted...
and how far the lugs go on to the 3 inch ARP studs with out the spacer
scarface
Guest
I didnt have to go that deap in cutting with my Draglites
1FastGT
stupid question but what did u grind the caliper with? :crazy2:
1FastGT
and isnt that slightly dangerous? i mean they designed that bracket for a reason.
scarface
Guest
cars were designed to run a front swaybar, but people still take them off. Maybe it isnt the thing to do, but it worked fine for me and I never had an issue... Cant say someone else will do it and there car will fall apart, its a chance they take.
Jrgunn5150
Do it at your own risk. No offense, but it would seem that at this stage in your modding career, you should run the spacer until you are more comfortable.
Mach1Fran
Barrie, ON, Canada
Hey guys, new to this forum. Trying to get 15x4 prostar skinnies on my 03 mach 1. I realized I have cobra brakes and you guys are running a lower pro GT caliper. Will this mod still work for me? Or should I get a spacer and ARP 3" studs? Thanks in advance.
RAU03MACH
NEW MEXICO
17x4.5
RAU03MACH
NEW MEXICO
did not use a spacer
the cobra brakes are not going to let the wheel sit flush on the hub
RAU03MACH
NEW MEXICO
these are 15x4.5 and barely clear the brake calipers
these are the stock gt brake calipers and these will fit any year gt model 80s 09
Mach1Fran
Barrie, ON, Canada
Im going to sell these 15x4.5s and get some 17x4s. Everything Im reading says its a direct fit for these fat cobra brakes.
Thanks for the quick responses brothers!!
Markstang73
