How to repair window motor bushing - 94/95 cars only
shades
Re: Window Problem 94-95 Only
Used this today and it worked PERFECTLY! Thank you for the right up!
-Shades
RJayLo
hmm. good to know! This is actually happening on my drivers side window. Good to know I dont have to take it in for this! Now I just need to figure out why the auto locks arent working with the button inside.
elaborate please.i might be able to help you too
RJayLo
when I press the unlock/lock button nothing happens. I think I read something about a fuse but Ill look into that some more. Neither the drivers side or passenger work.
does it works with the keyless entry (if equipped),here is the under hood fuses and the inside (pics)
[attachment deleted by admin]
RJayLo
thanks. Ill check it out but today the passenger unlock button did work so im starting to rule out the fuse issue.
RJayLo
awesome writeup!
Did my window motor fix just now and it came out cherry! sn95forums FTW! :dancing6:
1FastGT
ıʌɐɾ said:
1FastGT said:
you can put in 1/4" nuts. it actually works better cause they dont wear out and break down like the plastic rollers. thats what i did. :xmas-smiley-022:
ive heard about that,but nobody was able to prove it with pics,i will try that whenever i have to change them again :D
one of these days ill put the motor back out to take pics.
Wayne
came home from work yesterday went to roll up the drivers side window bump bump bump all the way up. :tickedoff: fix it today used the 1/4" nuts in place of the nylon bushings and it works great thanks for the write up. :TY: happy again :banana:
95vert50
Ok first I have to say that I'm ssssooo glad people like you are still around. Thanks for taking the time to write this tread. Second is it the 1/4 nuts or the 5/16 cause I'm seeing both posted?
Thanks Again man.
Thanks Again man.
No problem :thumb:
and i dont know which size nuts,cause i didnt use them. and yet i havent seen them with nuts
bens95svt
Just used this write up to fix my passenger side window ...THANKS!!!!
New 5.0
You Saved Me Like $60 bucks. Good Write Up!
:TY:
:TY:
I have paypal if you want to send some of the $60 my way :hammer:
:welcome:
aerodorcho
Wow i'm really glad I saw this thread It saved me a lot of money. I used the 1/4 nuts and it works perfectly! But the whole process was a little harder than I thought.
Thanks for the excellent write up!
AHayes88
So is it a 5/16 or 1/4 nut that fits in there instead of the plastic things?
It's summer, I don't have AC, and my passenger window won't roll down but I can hear the motor trying to work.
Markstang73
