How to shave your 94-98 trunk!
330CubeGt
Also did this write-up when i had the 98Gt so its a little old but still useful if your wanting to be different
Went wingless and had to fill the holes.Along with filling the holes i also filled in the holes for the factory ford emblem.After thinking about it i said ah what the heck ill fill in the seam around the Tag to.Short and Sweet but if you have basic hands on skills this can be done in an afternoon
Items Used: The Body Filler that was used is Bondo Glass.Also pick up a few Spreader Pads.(2) Cans Primer and (2) Cans Paint.
Bondo-Glass is a unique reinforced filler containing short, interlocking fiberglass strands and fibers that make it twice as strong as regular body filler. Repairs small (dime size or smaller) rusted-out metal holes and shattered fiberglass body parts. PERFECT FOR MARINE USE! Eliminates the need for backing strips, fiberglass resin or cloth on small holes and rusted out areas. Sandable in only 20 minutes and compatible with all paint systems. Waterproof. Includes Red Cream Hardener.
I Removed the Third Brake light (2) 10mm Nuts and got to work.Using 300 Grit sand paper and my Porter Cable E-Sander.
300 Grit is pretty tough so don't stay in one place for to long.Keep in mind if you do not have a Sander this job can be done by hand if all your doing is filling the wing holes.
I Removed the Ford Emblem with a small flat head Screw Driver.Then Hit that area with the sander this is what it should look like.
After thats done Move on to the Seam around the tag along with the wing holes.
Once this is done you need to put somthing behind the wing holes along with the emblem, in my case i used a small amount of epoxy on a square piece of aluminum and stuck it behind each hole.If you try to do this next step with out putting something behind the holes the Bondo Glass will sag through the holes and end up every where but where you want it.
Now your Ready to mix.I advise you to read the instrutions for mixing in the hardener.In my case what ever the amount of bondo glass i just make a X over the bondo glass and get to mixing.After mixed you only have a limited time to work with the bondo glass before it gets hard.If your not scared of sanding you can apply it think or if you want to save yourself some work apply it a bit lighter.
Then this is how it should look once applyed.
Same goes to the Wing Holes. After it hardened i used a fresh piece of 300 Grit once again to knock it down quickly you might want to use a little less abraisive Grit but thats all i had.Then it should look somthing like this.
Once you get it to being smooth to the touch.with no ripples/air pocket, and your happy with it.your ready to tape off around the trunk use some blue painters tape and some old newspaper and get ready for primer.After you tape it off wipe down the surface area your ready to hit it with some primer,Don't forget to shake it good before you spray.In my case i used Grey Sandable/Filler Primer to help fill in any small imperfections.This is what it should look like after laying on the first coat.
After about 1.5-2 Cans of Primer it should look like this.
After you have it completly covered in primer your Ready to sand it smooth.In my case only having 300 Grit i used an old piece that was kinda wore out.If you can use something a little less harsh maby 800 Grit would be better.Once you have it smooth and even you can get ready for paint.I then again Taped off the Trunk and applyed one coat of Rustoleum Gloss Black paint.
After the first coat drys i hit it with some wet sand paper 1000 Grit and 1500 Grit to get it as smooth as can be.Then i applied 3 more coats of gloss back paint. About $25-30 in supplies and an afternoon of work.
I am by no means good at body work but i try.Someone with more know how on body work im sure can do a much better job.
This is the End Result.
the5.ohh
Shaolin, NY
Doesn't look that difficult. Nice write up man, this will definitely help a lot of us out
330CubeGt
Its not to hard.Inever had anyone show me the "right" way to do body work and I'm decent at it.Even if the project takes you all day its still worth it if you want a custom touch.
same thing I did on mine but I also smoothed in a s281 spoiler as well as the 3rd tail light, also relocated the keyhole behind the license plate. Only thing I would have recommended was some tape around the area you are glassing will save you a good 20-30 mins of sanding the edges out.
baddbradd
You did a good job!. I may try this with my old decklid, just to "practice"
ndfrspd
THE MOTOR CITY, MI
yo man it looks good, really nice job. however, if you were to ever replace the trunk key lock cylinder, you would have to remove that cover plate where the license plate goes, breaking all that bondo/filler around the crack. but otherwise, nice job, i was going to do this myself sooner or later as well.
FivepointSlow
Enfield, CT, USA
[MENTION=10623]330CubeGt[/MENTION]
Do you have any more pictures of the shaved trunk?
I filled my badge holes on my wing trunk (I have 1 trunk with a wing and one that's wingless) and I'm debating shaving the license plate surround before I go repainting it.
Crapatalkin' on the iPhone 5.0
I used 3m panel bonding adhesive to hold it in place and fill the gap first then filled with short hair reiniforced filler.
FivepointSlow
Enfield, CT, USA
Yea I love your trunk but I wanted to see a trunk with no wing or a stock wing to get a better idea because I'd never go as far as to smooth a wing into the trunk. Lol
I wasn't sure since his has no spoiler.
That's a lot of space to be filling with bondo.
its an S281 spoiler that had a nice/tight fit. Like I said the panel bonding adhesive did the majority of the fill.
NERD
Virginia
I was referring to the two piece decklid not the wing. :)
whiplash473
Northern IL
Simplified: Sand hole area with 120 down to bare metal. Weld holes closed. Grind holes down with grinder of choice. Apply filler over ground welds. Sand smooth. Prime. Sand smooth. Apply basecoat. Apply clearcoat. Sand, buff.
Sent from bored/stroked HTC One
RevJon
