i wanna build a bad ass modular. help me.
cody0170
currently i have 118k miles. want to put a kenne bell on it but am afraid of breaking stuff with the miles. should i get a used pi short block and get some nice heads/cams and use the intake plenum, throttle body, cai etc. or do all that to my motor now but rebuild the bottom end and if i do that should i stroke it or just bore it 30 over. if you have any prices to compare that would be great as well.
C
cody0170
whats a good h/c/i combo. i have a setup for 50-150 nos but use it rarely. if i get a setup for a supercharger willi suffer until the supercharger is installed
Jrgunn5150
A PI shortblock is no stronger than the one you have now. If you want a "whoa holy crap my car is friggen fast" fix on the quick (because Kenne Bell's cost like 7k), throw on some stock PI heads (2-3 hundred), VT Stage I N/A cam's if you can find them, or Comp 262's if you can't (4-5 hundred), misc gasket's and an intake if you don't have one (250) and for 1200 buck's you'll be knocking on the door of 300 rwhp and that should hold you until you build a shortblock.
Dalamar
SLC, UT
if your adding a KB, don't worry about the ported heads (unless you want)
and the blower replces the IM.
I'd recommend a forged internals or shortblock.
you could also lower your compression to get the most out of the blower combo.
there's a number of good sources out there. Crower makes a nice cam as well if your looking.
that will be a fun car when your done. good luck with it.
AaRoN
King Post Whore
Yeah. What he ^ said. He's got a bada-- modular. :santa_grin:
C
cody0170
if i was to throw on some stock pi heads with vt stage 2 heads w/ my mods w/ out nitrous what time hp increase will i prolly see? track time?
Dalamar
SLC, UT
PI heads and cams usually net between 75-100 HP.
you'll need a dnyo tune as your compression will go up, and the valve timing will be different.
track time - 13's depending on your skillz :santa_smiley:
AaRoN
King Post Whore
Yeah unfortunately for me a PI swap on an NPI motor nets more power than an actual PI motor :(
C
cody0170
where in oklahoma does good dyno tunes and for how much?
C
cody0170
do i need adjustable timing gear, different valve springs?
C
cody0170
why are people saying go with stage 1 comp or vt cams why not stage 2
North of okc at SWtuning,his name is jim, www.swtuning.com
he is pretty $$$$$
he is really good ive seen the green bullitt (his partners car) 500hp (2v) to the wheels
Jrgunn5150
Because you need to swap springs for the duration that those cams run.
C
cody0170
ok well those are like 180 dollars plus retainers and besides more of a lope will it run any different
Jrgunn5150
Yeah, it'll run faster :D You don't need new retainer's with spring's BTW.
You can't E-race forever though dude, eventually you'll have to go get your hands dirty.
C
cody0170
anyone have a sound/vidoe clip of a pi head swap with a vt 1 or 2 heads
RevJon
