im looking at building my 96 mustang gt to make 400+whp
96prpl2v
So the car has the 4.6l 2v npi and i’m looking to make 400whp or more
here are the mods i already have
-K&N CAI
-78MM ThrottleBody
-4.10 gears
-full exhaust longtubes headers to a catless x pipe with 2 high flow mufflers and a magnaflow cat back tail pipes
-decent amount of suspension work
the car as it sits is fun but is only making around 240-250whp and i think i would be able to achieve 400s for decently cheap which i want the most bang for my buck to save money
My thought process on how to make cheap power:
-PI Swap
-HandHeld Tuner from AmericanMuscle
-UnderDrive Pulleys
-ZEX N2O Kit adjustable for 75-125 shot
then i think with this setup i would be able to make 350-400 but after doing the math i would only have to spend around 1700$ what’s your guys thoughts? am i missing any supporting mods? will my setup be safe with a stock block and a 125 shot? and the big question is will the car be making upper 300s thanks!
Lawrenceburg Kentucky
Get a 1.840" intake valve in the pi heads. Get a nasty cam with a 106lsa, something like comps 274 / 278 cam reground to 106lsa. An edelbrock intake manifold. The intake will favor the nitrous far better than a stock intake. Some headers(and hate yourself for installing them). This will get you well over 300rwhp
96prpl2v
if this is a DD that spends time in traffic save the $$ on the pullies.
nope not a daily driver for me i have a truck that i am gonna have be my daily and the mustang will be the project/money pit
96prpl2v
i already have a offer for a full PI Swap for this car like,cams,intake,intake valve, ported heads and whatever else i missed but yeah and i already have some BBK long tube headers
i would like to do this but i don’t have the money to purchase that i’m only 16 with a part time job
well the parts it will take cost just as much now and days
who doing the work if you saved money
if a shop spent money
horse power is not as cheap as it used to be
badass98svt
I honestly don't see your mods giving you 240-250 rwhp with a NPI 4.6
I'd do the PI stuff you already have on your way, then throw a Vortech on it and call it a day.
96prpl2v
well with lower ride height, full exhaust, the intake stuff throttle body,4.10gears, short throw shifter and probably some other small stuff i’m forgetting i believe i made a 0-90 on a back road at about 9-10 seconds to 90 i’ll post the video if it allows me to
96prpl2v
won’t let me post video but if anyone is trying to help me out i would be glad to show them videos and stuff thanks!
correct but don't forget the bottle then is I think how he is calculating 400 in the end
96prpl2v
Yup you got it
i figured stock it made around 210-215 then with the smaller stuff like gears,cai,tb,suspension,etc it would be around the 240-250 mark as it sits as of now then i’m hoping with the PI Swap and a wet shot i’m thinking i might want to go with a 125 shot
/do you guys think with what i have right now i could run a 125 or 150 wet shot on 93 pump gas and dyno tune?
Musturd
I’d just do a Vortech at 10lbs with supporting fuel mods you’ll make your goal and the car will be a blast
apsmith49921
What he meant was the car makes 215 stock at the crank. They often dyno in the 180s at the wheel. Toss on you mods and it's probably closer to 215 wheel at that point. A pi swap good cams and the rest of the bolt on mods will get you close to 300 at the tire with a little help coming from the NPI bottom end. I'd start there. 300 wheel from 215 is a hell of a difference. If you plan on buying cams plenty used sets to be found. And from experience I recommend changing the valve springs before you put the heads on. Your life will be easier trust me
badass98svt
Yup you got it
Again, 210-215 HP is not the stock RWHP, that is the stock HP rating at the crank
Also Gears, suspension, shifter etc dont add any HP.
A stock NPI 4.6 will make about 175-185 RWHP.
Full bolt ons, you'd be lucky to see 200-210 RWHP (UDP, CAI, exhaust, etc etc)
If I had to guess, I'd say you're currently around 190-195 RWHP.
A Vortech at 8-10 lbs would net you 300 RWHP, give or take a few.
But don't worry about chasing #s, just enjoy the car.
mwright19832
