Injectors?
Michael Plummer
Brockton, MA
Are the EV6 style injectors the same length as the EV1 style injectors?
Yes, EV6 and EV1 injectors are basically the same length.
More information on injectors: Mustang can use two different style connectors (Jetronic/Minitimer or USCAR). There is a 3rd EV14 but not to many people use them.
* Mustangs from 1986-2004 use the Jetronic/Minitimer style injectors.
* Mustangs from 1999-2004 (4.6L 4V Mustangs (SVT Cobra & Mach 1)) and 2005-2015 Mustangs use USCAR style connector.
* Ford Racing also sells the adapter harness so you can adapt USCAR stlye harness to a Minitimer/Jetronic injector or a Minitimer harness to a USCAR injector.
More helpful information with pictures: http://www.paladinmicro.com/documents/Fuel_Injectors_and_Adaptors.pdf
The later style is supposed to be a better version due to spray pattern.
You can get the adapters at LRS, AM etc.
wmfateam
Gilbert, AZ
I hear "better spray pattern" way too much. The internals and the coil are what make the injector better. The EV14s also don't weigh a thousand pounds.
wmfateam
Gilbert, AZ
jackcrickson
I guess basically the same means they are slightly different. I wonder how much is the difference?
FHCee
