NEED HELP Misfires + bank too lean
Shrek51
Hey everyone, i’m not a huge car guy so i appreciate all the help on here
My 95 V6 is throwing out a misfire code on 3 and 4, as well as Bank too lean bay 1 and 2. I’ve done spark plugs and MAF sensor so far, wondering what you guys recommend i look at next. People i’ve talked to say it may be coil pack, which might be my next one given that it’s apparently a easy thing to replace
any help or insight is appreciated! i’m really not a mechanic i’m a highschool kid who can’t afford shop fees
dalpoas83
if bank 1 and 2 are lean that may be indicating a vacuum leak. Lot of these older cars have old deteriorated vacuum hoses.
Use caution if you don’t know what you are doing at all this may just be better left to someone else or get some help. That being said
I’d recommend trying this and see if you find a vacuum leak.
shovel
You can measure the coil pack and test it before firing the parts cannon. Coil pack and vacuum leak are both plausible and it would not be a waste to replace all the decades old vacuum lines under the hood
T's Convertible
