New combo,new time
G_94_T
TN
Went to the track last night with the new combo..,,not thrilled but not [email protected] 60ft
Gt40 iron heads
Explorer intake
Lunati cam. 522 lift,215 int,224 ext duration
Scorpion 1.6 rr
3.55 gear
Upr k-member
Upr pro series rear lca
Stock tb
Pro M maf for 24lb injectors
24lb 4 hole injectors
Trick Flow valve springs
U/d pulleys
Bbk longtubes
O/r h pipe
G
G_94_T
TN
1.5" SVE lowering springs
190 fuel pump
Engine has 600 miles on it after rebuild....stock bottom end with new bearings,rings,and main and head studs
G
G_94_T
TN
Track was Bristol Dragway in Tn
14* timing on 93 octane
G
G_94_T
TN
Shifting at 5500 rpms.....should've tried 6000 but didn't get the chance
McCloud
Johnson City, TN
You've got room left to improve with your 60 and getting it below 2.0 will get you in the 13s. That's a respectable time for Bristol. They typically don't prep the track very well for Street Fights (or at least they didn't a couple years ago when I stopped going).
My best time there with my new combo was a 12.91 @ 107 with a 2.0 60' on DRs lol
1997GT4.6
Not a bad time. Work on that 60, and you'll drop into the 13s.
G
G_94_T
TN
I know 60ft is key,but i thought mph would be a little higher
cameron57
What gear were you in at the end of the traps?
G
G_94_T
TN
Just went 4th....again this is shifting at 5500....if i had shifted at 6000 i think i could have stayed in 3rd
Doodler
What kind of tires do you have and what are you launching at?
RichV
CO
Put a few more miles on that motor and let it break in. But a dyno will tell you if you can shift at 6K if you're not dropping power yet. 5500 is about it for my HCI GT40 5.0.
Honestly 100MPH depending on your weight is not bad. Do you have gears?
DavidBoren
Pacific Northwest.
He has 3.55 gears. Which should be fine. 373's or even 410's may help, but to me this looks like it's the indian, not the arrow.
Work on that 60' time, brother.
G
G_94_T
TN
Yeah dyno soon to come for just that purpose
kb1982
Kentucky
If you were just getting into 4th, go ahead a wind third out a little more. When I used to run one of my motorcycles in the 1/8, i would pop the rev limiter 4 or 5 ft before the finish line. It was still quicker doing that than shifting into 3rd
G
G_94_T
TN
Interesting....thanks for the tip
SLOW95GTS
You should try taking off like a normal stop light it will most likely not spin or slip the clutch at 2k rpm. Rev it out until you feel it still pulling, I usually go to 6k-6200
G
G_94_T
TN
SLOW95GTS;134834p I usually go to 6k-6200[/QUOTE said:
Dont know that my combo will support that rpm
Dont know that my combo will support that rpm....cam range is 1500-5500 rpm
barski
