NEW LED'S DON'T WANT TO LIGHT!
RICKERMAN
In the past 2 days I have installed 2 different sets of brand new LED bulbs in my 1996 GT gauge cluster. None have worked. I reversed the polarity 180 degrees on a couple of bulbs each time but still, none will light. Everything else, warning lights, headlights, taillights, emergency flashers, etc.works fine. When I pull on the headlights, which work fine too, the radio and clock lights dim as usual when that energy is drawn to the headlights. Everything seems fine except the most important thing; none of my 2 different sets of LED lights will light up. WTF am I missing or doing wrong here?? Any thoughts or ideas???
Please HELP!!
take the cluster out and look at the connection where the harness plugs into it. The way they made them there are copper traces that can come loose and then when you plug it in it pushes the trace out of the way or shorts it out.
R
RICKERMAN
Could be. Removal of the harnesses AND the cluster are pretty difficult, let alone the reinstallation. If one of the copper traces is out of place can I fix it?? How can I tell if something might be "shorted out" and if so, how screwed am I?? I appreciate your response and suggestions very much. EVERYTHING else works fine. ALL lights inside and out. I rarely drive this car when I actually NEED the gauges to be lit, and as you probably know, the original gauge lighting is barely visible unless it IS dark out. I bought this SHELBY COBRA convertible NEW in 1996 from Carroll Shelby himself who was a friend of my Dad's who made the connection for me.
I have kept it in prime condition and thought that these blue LED's would spiff it up a little. The car's moonlight blue with white top and white leather. Thanks again, hope I can git'r dun!
pulling it apart and inspecting it, if there is a loose trace you will probably be able to see it and yes a little rtv on the back once dry will help to hold it in place.
Also just to be stupid take a trip through the fuse boxes and check all the fuses.
Daryl
SoCal
Sidebar: a pristine’96 Shelby convertible?? Carroll Shelby’s??
Oh, you GOTTA post pics of that! Giterdun!
badass98svt
Never heard of any moonlight blue Cobras. Post some pics
R
RICKERMAN
As you say, if there's a "loose trace" try a little "rtv" .
What is "rtv"?
Daryl
SoCal
Room Temperature Vulcanizing
It’s a silicone adhesive.
R
RICKERMAN
Ok, I looked into it. Would you recommend rtv-1 "liquid"?
The description I read sounds like that the liquid form might be my better choice. Please let me know what you think. Thank you kind Sir!
I was just talking about the silicon I get at autozone. Just be careful to keep it off of the top and it should help to hold the trace line down and in place.
R
RICKERMAN
What is "rtv"?
I did get the RTV but haven't tried it yet. If, as you suggest, it could have "shorted out", will it work after re-aligning and applying a little RTV?
RevJon
