Post your mods!! (SBF)
white95
Apex Junky
Admin
Prairieville, LA
I'd like to see what everyone has done to their cars!! Copy and paste this template and fill in YOUR mods!!
Engine/under hood/ECU :
Drivetrain:
Chassis/wheels/tires:
Interior:
Exterior:
other:
white95
white95
Apex Junky
Admin
Prairieville, LA
Engine:
- 410w
- EZ6M-6015-G351 SVO block (4.040" x 4.00)
- Eagle ESP 4340 crank
- Eagle ESP H-beam rods, internally balanced
- SRP Pistons (-19 cc/10.8:1 ratio)
- ARP rod bolts, ARP main studs
- Canton 7 qt oil pan
- Procomp 210 cc heads
- 2.02 x 1.60 stainless valves
- titanium locks/retainers
- EPW 1.6 ratio RR
- Trick Flow stage 3 cam
- Comp Cams linked bar roller lifters
- Comp Cams pushrods
- ARP head bolts
- Edelbrock valve covers
- Edelbrock Performer RPM 351 (powder coated red)
- 75 mm throttle body
- #42 injectors
- S197 MAS
- custom fender well CAI
- Aeromotive fuel rails
- black fuel lines/fittings
- AEM, externally mounted fuel pressure regulator
- 190 lph in-tank pump
- '95 Lightning distributor
- MSD cap/rotor/coil
- Taylor plug wires
- T4M0 ECU with Moates multiple tune/flip chip
- BBK unequal length headers
- Prochamber 2.5"
- MAC 2.5" cat back (3" tips)
Drivetrain:
- Tremec 3550
- Pro 5.0 shifter with Steeda handle
- Spec Stage 2+ clutch
- Adjustable clutch cable
- Steeda double hook quadrant
- 8.8 traction-lock SRA (completely rebuilt)
- 3.73 gears
- FRPP aluminum driveshaft
- QA1 tubular crossmember
- BBK specific rate coils, 1.5" drop
- 2003 Cobra Bilstein Struts
- Maximum Motorsports CC plates
- Energy suspension sway bar end-links/sway bar bushings
- 95 Cobra front sway bar
- Maximum Motorsports subframe connectors
- tubular Upper and Lower control arms
- 96 cobra rear sway bar
- Bilstein HD shocks
- 18x8.5" Konig Maxxim wheels
- 245/40-18 nankang NS2
- 295/35-18 Continental ContiSport 2
Interior:
- red leather S197 seats
- converted to black interior
- 98 center console
Exterior:
- vertical tail lights
- S351 wing
- 4" Cobra R hood
- BOI Cobra headlights - clear corners
- 8000k HIDs
- yellow foglights
- horrible paint
- painted gas tank cover
Other:
Alpine CDA-9855
Alpine S-type 6x8 (door)
Rockford Fosgate 6x8 (deck)
Viper Alarm
Parts awaiting installation:
2003 Cobra IRS (pending a FTBR overhaul
Air conditioning
Boston Acoustic 6x9's
Alpine 4-channel amp
BBK 1 3/4" longtube headers
Musturd
1994 musturd Gt
Engine/under hood/ecu:
forged 306 probe pistons stock rods and crank
Gt40 heads
f303 cam
ported shit box typhoon manifold
75mm bbk throttle body
frpp 24lb injectors
bbk 1 5/8 long tube headers and off road x pipe.
Nos universal wet kit. 125 shot
t4mo computer with 4 bank chip.
Drivetrain :
g force t5
act clutch pt # FM1-HDSS
CENTERFORCE billet steel flywheel
b&m pro ripper shifter
frpp aluminum drive shaft
Eaton 31 spline carrier
3.73 gears
moser axles
Scott drake diff girdle
chassis/wheels/tires :
13" bullit/cobra brakes and 11.65 rear cobra brakes
upr tubular k member and control arms
upr front coilivers strange struts
upr caster camber plates
upr bumps tower kit
Upr rear coilivers strange shocks
upr pro series rear control arms
custom through floor subframe connectors
custom rear strut brace .
20x9 20x10 foose speedsters 245/35/20 285/30/20 BFG g force kdw2's
bogart d10 drag wheels 15x4 and 15x10 with Mickey sportsman front runners and Mickey Thompson 26x11.50 et street slicks
interior :
MM 6pt cage
acura RSX leather front buckets
custom rear seat delete
autometer monster tach
led cluster mod
pioneer double din
hurst sidewinder.
Exterior :
Cobra hood
cobra headlights
cobra fog lights
cobra front bumper
cobra rear bumper
shaved key holes
shaved 3rd brake light
no spoiler .
RichV
CO
1994 GT
302, stock pistons/rods
GT40p heads stock ports/valves
BBK fox headers
SN Cobra intake
e303
stock injectors/MAF
ProM PIH with A9P ECU
Drivetrain:
stock T5
8.8 w/3:73
FMS aluminum driveshaft
1 5/8" DOM 6 point cage with NASCAR style driver side bars
MM 4 point k-member brace
unknown STB
MM panhard bar
J&M rear LCAs
Global West Del-Alum front CA bushings
Koni SA front shocks
Bilstein HD rear shocks
H&R Race Springs
1.25" rear Eibach spacers
rear Cobra sway bar, OEM GT front
4x MB Competition 17"x9"
4x OEM '03 Cobras 17"x9"
13" front brakes with Wilwood 4 piston calipers
OEM Cobra rear vented brakes
Cobra MC
MM CC plates
275/40 R17 TOYO RA1 tires
Interior:
all carpet/interior removed except dash
Sparco EVO seat
G-Force 5 point camlock harness
battery box in passenger seat area
Firecharger 2 nozzle system with pull lever in center console
G-Force window and side nets
50lbs of ballast in passenger seat area
Exterior:
decals
brake coolers in OEM foglight holes
tow straps in front and rear
Cobra crabclaw
COBRA BADGES! :)
the5.ohh
Shaolin, NY
I think mines too much haha.
Engine/under hood/ECU : Stock 302 block. Ram air intake, 76mm maf
Drivetrain: Stock except Ratchet shifter
Chassis/wheels/tires: Stock.. for now.
Interior:Ratchet shifter, black ball shift knob.
Exterior: Window tint, sidemarker tint, headlight covers, blacked out and cleared pony grille emblem, sn95forums decals, stainless steel bumper letter inserts, 6k LED reverse light bulb, cool white LED license plate bulbs, new edge GT fender badges
other:
jwhisl
Oklahoma
Most of this is in my fox, Will be under the hood of my 95 in 2 months!!!
XXX 302 bored .60 speed pro hyper-eutectic pistons, ported e7's 2.02/1.60 valves, 1.77rr, b303, Typhoon intake, 75mm tb, bbk cai, 30lb injectors, bbk shorties, O/R Xpipe, Mac catback
Drivetrain:
Tremec M7003Z HD transmission
OE Racing 18" Staggered cobra knock-offs, 2004 Mach1 springs
Interior:
Blue under-dash led's, 2007 front and rear seats (soon!)
Exterior:
Smoked Halo HID's, tint
other:
MB Quart fronts, Infinity kappa rear, 10" alpine r's in trunk
Paul
2011 Mustang GT...
None, and I still have more power than those PI shitboxes, and cobras.
Drivetrain:
None, but I'll probably get my axle tubes welded.
Forgestar F14 Wheels, Brushed Titanium Finish, Deep Concave, 20x9 and 20x11
Hankook Ventus V12 Evo Tires, 275/30/20 and 305/25/20
Koni STR.T shocks/struts
Steeda Ultralite Springs
GT500 Strut Mounts
Interior:
None. Car came big pimpin' with factory premium leather, navigation, leather wheel, contrast stitching, heated seats, and a glass roof.
Exterior:
Boss 302 Front Valance, Boss 302 Splitter, Boss 302 Rear Valance, Roush Rocker Panel Splitters, GT500 Mud Flaps, GT/CS Rear Wing, Saleen Grille, GT/CS Foglights, Factory-Installed Hoodscoop
other:
5.0 rules your whole face.
Paul.
ProKiller
PA
Engine:
-D.S.S. Super Pro Bullet 331 Stroker block with Series 20 upgrade
-Forged D.S.S. Pro-Lite Pistons
-Forged D.S.S. H-beam rods
-Cast Stroker Crank
-Felpro MLS head gaskets
-D.S.S. Windage Tray
-D.S.S. Main Support Girdle
-D.S.S. 7qt. Oil pan with FMS High Volume Oil Pump
-Vortech S-trim SQ-V2 (2.95" pulley)
-AFM Power Pipe
-AFR Competition 185 58cc heads
-Trick Flow Stud Mount 1.72 Roller Rockers
-Moroso fabricated aluminum valve covers w/ JIC fittings for breather
-Moroso breather tank w/ JIC fittings/lines
-AFM B-21 Cam (218/226 .542/.542 w/1.7 rocker 272/280 112 108)
-FRPP lifters
-Edelbrock Performer RPM intake
-1" phenolic intake spacer
-Stack Racing Polished 70mm Throttle Body
-Pro-M 80MM mass air w/ attached filter
-42lb FRPP Injectors
-Aeromotive Fuel Pressure Regulator
-PA Performance 130-amp Alternator
-BBK 1 5/8" ceramic coated long tube headers
-Dr. Gas 2 1/2" x-pipe
-DynoMax race bullet mufflers
-Borla dual slant cut round intercooled exhaust tips for side exhaust
-255lph intank fuel pump
-T-Rex inline fuel pump
-MSD Pro-Billet Distributor
-MSD coil
-MSD 8mm plug wires
-MSD 6A Ignition system mounted in glove box
-Fluidyne Aluminum Radiator
-Manual Fan switch
-AFM PMS w/ boost controller
-Billet Smog Pump Delete (99.5" belt)
-Most wires hidden
-EGR Deleted -A/C Deleted
-Snow Methonal Injection Stage 2 kit (waiting for install)
Drivetrain:
-Tremec 3550 upgraded with 26-spline input shaft and larger output shaft
-Mcleod clutch
-Fidanza steel flywheel
-Maximum Motorsports Clutch Cable
-Steeda Double Clutch Quadrant
-American Muscle Firewall Adjuster
-Pro 5.0 shifter
-Ford Motorsports Aluminum Driveshaft
-FRPP Driveshaft Safety Loop
-Hurst Line-Loc (Waiting for install)
-Ford Motorsports 3.73 gears
-Moser 28-spline axles
-Trick Flow Rear Stud Girdle
-Royal Purple dif fluid
-ABS deleted
Chassis:
-Ford Racing Lowering Springs (I think C's)
-KYB Rear Shocks
-Steeda Aluminum Lower Control Arms
-Steeda Adjustable Upper Control Arms
-Maximum Motorsports 4-bolt Caster/Camber Plates
-BBK Strut Tower Brace-Kenny Brown full length welded in subframe connectors
-2003 Cobra Rack (SPR-ZM)
-FRPP rear cobra conversion kit
-Brembo slotted rotors
-Hawk HPS pads
-J&M stainless steel brake lines
-Front brakes, lines, rotors (awaiting install)
Exterior:
-Fresh paint job :: Black with blue pearl, ghost blue pearl dual stripes
-Cervinis '95 Cobra R Hood w/ Hood Pins
-ABC Exclusives GTR front bumper smoothed on the sides
-Roush side exhaust side skirts
-Saleen T1 race spoiler
-Export horizontal tail lights w/ amber turn signals
-LED reverse light bulbs
-LED license plate bulbs
-Black Bullit fuel door
-Ultra Clear Headlights
-Ultra Clear Side Markers
-Clear Rear Reflectors
-18 x 9 FR500 Hypercoated front wheels
-265/35-18 Nitto NT555 Extreme front tires
-18 x 10 FR500 Hypercoated rear wheels
-305/35-18 Nitto NT555R drag radials
-Window Tint
-Silver Bumper Inserts
-Painted Mirrors
Interior:
-Painted Interior pieces
-White Face Gauges w/ LED light mod and red needles
-Sinus Industries Gauge Ring Bezel
-White HVAC panel w/ LED light mod
-LED Reverse lights
-Autometer 2 gauge pillar pod
-Autometer 2 gauge cluster pod
-Autometer 2 gauge clock pod converted for wideband
-Autometer C2 Boost, Water Temperature, Oil Pressure, Fuel Pressure gauges
-Autometer C2 Tachometer w/ UPR Tach Bracket
-AFM Uego 2000 wideband sensor (partially installed. Still have to hook up to Tach/PMS)
-Bullit Shifter Knob
-Billet Headlight Knob
-Billet Window Switches
-Billet Clothes Hangers
-Billet HVAC Contols
-Billet Cigeratte Lighter
-Billet E-Brake Handle
-Billet Door Lock Pins
-Billet Cruise Control Buttons
-AFM Billet Ash Tray Switch
-Neon Blue Lights under the dash
-Aluminum Trunk Mounted Battery box (waiting for install)
Stereo:
-Pioneer headunit
-Pioneer tweeters
-Viper Alarm
-Mach 460 Rear Deck Box w/ Amps (waiting for install
rz5.0
Great state of TEXAS
stock rebuilt 302 .40 over,
AFR 185 58cc,
TFS Stage one cam
TFS Track Heat intake
comp cams 1.6 rockers
vortech t trim intercooled
turbo smart bov
siemens 80lbs injectors
vmp slot style maf (blow thru)
bbk long tubes
bbk mid pipe
Drivetrain:
stock t5
B&M ripper short throw shifter
stock replacement clutch
03/04 aluminum cobra driveshaft
03/04 IRS
UPR K MEMBER
UPR A ARMS
UPR COIL OVER
UPR CC PLATES(SOON TO BE MM)
MM SUBFRAMES
COBRA BREAKS FRONT AND REAR
RPF1
Interior:
STOCK
Exterior:
STOCK
OTHER:
TUNING
MOATES QH
BE
ECCA
INNOVATE LC1
Venom351R
Maine
*Cracks Knuckles* Here we go.
- 351W From a Cobra R
- Trickflow CNC 234HR High port heads
- Custom Cam from FTI
- Edelbrock Victor 5.8
- FMS #36Lb Injectors
- Kirban FPR
- BBK Fuel Pressure Gauge
- Livewire Spark Plug Wires
- Accufab 75MM TB
- PMAS 95MM Mass Air Meter
- Stewart Water Pump
- 2 Core Aluminum Radiator
- Screaming Demon Coil
- No Smog / No AC
- Accufab 1 3/4 Long Tubes
- Trickflow 1.7 Roller Rockers
- SCT Chip
Drivetrain:
- Tremec 3550
- Pro 5.0 Shifter
- Centerforce Dual Friction Clutch
- FMS 4.10's
- FMS 31 Spline Limited Slip Differential
- Moser 31 Spline Axles
- MAC Differential Girdle
- Adjustable clutch Quadrant / Firewall Adjuster
- FMS Driveshaft Safety Loop
- Cobra R Drive shaft
- Kenny Brown 6 Point Street Cage
- Roush Subframe Connectors
- Maximum Motorsport 4 Bolt Caster Camber Plates
- Team Z K Member
- Team Z A Arms
- Team Z Double Adjustable Upper Control Arms
- Maximum Motorsports Lower Control Arms
- Spherical Solid Rear Bushings ( UCA )
- Team Z Coil over Kit w/ #170 Springs
- Strange 10 Way Shocks / Struts
- Stock Rear Coils Cut 1 Coil
- Cobra R 17X9 Front Wheels With BF Goodrich KDW2's 255's
- Cobra R 17X10.5 Rear Wheels Nitto 315's
Interior:
- Autometer Water Temp Gauge
- Autometer Oil PSI Gauge
- Autometer Dual Gauge Pod ( Clock Delete )
- Rear Seat Delete
Exterior:
- Cobra R 3.5" Rise hood
- Shorty Antenna
Other:
- Pioneer Head Unit
- Mach Sound system
- SSBC 3 Piston Calipers
- 13" Slotted Rotors
- Stainless Steel Brake Lines
- Hawk Brake Pads
- Amsoil Engine Oil
- Amsoil Rear Differential Oil
- Royal Purple Transmission Oil
GTfiveoh
Des Moines, Iowa
I don't know most of my stuff cuz most was done before I got the car, this list is what I've been able to figure out on my own which is not much
trickflow intake
Trickflow stage 1 cam
O/R h-pipe
Magnaflow mufflers
Custom tailpipes
(On the way) 22inch cherry bomb 3.5 tips
Ford racing plug wires
Drivetrain:
Short shifter (unknown brand)
Lowered on Eibachs
18 inch chrome Saleens 9/10
245/40/18 uniroyal tiger paws
285/40/18 goodyear eagle f1 supercars
Interior:
5.0 custom shift knob
Exterior:
Silver bumper inserts
Coyote 5.0 badges
Mustang windshield banner
(On the way) s281 spoiler
Smoked cobra headlights w/clear corners
Verticals (switched back for sequentials)
Future installs waiting to happen:
Kenwood Kdc-x995 head unit
JL audio amp
10 inch Phoenix gold subwoofer
kozz167
Whidbey Island Washington
A 95 351W 0.030 over fresh, Stock crank and rods, -8.6 dish pistons all with a fine balance.
High volume oil pump.
ARP main, head, and intake studs.
ARP bolts every wear else.
Ford Racing oil pan.
Edlelbrock E205 heads lapped and faced.
Edlelbrock Rolling Thunder cam.
Comp Cams Roller Tip rockers 1.6:1.
Hardened push rods. Don't remember brand.
TFS 75mm R series intake.
Airamotive fuel rails.
Holly 42lbs injectors.
Professional Products fuel regulator.
Professional Products 75mm throttle body.
DBX 90mm maf.
Built Distributors distributor.
Crane Cams HI H6 and coil.
High flow Water pump.
High flow power searing pump.
No A/C or poly, smog pump delet, under drive pulleys, Steeda tentioner poly and idler poly.
Remote oil filter.
1990 RX7 oil cooler with therm o bypass valve.
Oil breather can.
Steel beaded lines for everything.
Anderson PMS.
Doug's long tube headers (1 3/4" primaries 3" collectors).
Pipes X pipe 2.5" modified to fit longs.
Jardine cat back 2.5' for IRS.
Drivetrain:
T56 (ten spline input shaft),
Speck stage two clutch. (presser plate is balanced with rotating assembly)
157 tooth flywheel.
Ford Racing aluminum drive shaft (shortened and balanced).
03 Cobra IRS 3:55's (Full Tilt Buggy complete bushing kit and bump steer kit)
Ford Racing IRS dif cover.
Koni adjustable struts/shocks.
H&R rear springs (red).
Ebock rear sway bar.
Grigs coil over springs 400lbs front.
MMS front coil over kit.
Grigs caster camber plates.
UPR K member.
UPR A arms
Suspension Tech front sway bar.
Steeda sway bar mounts.
Rack pump steer bushings.
Steeda bump sear ball joints.
03 Cobra front and rear brakes.
American Muscle FR500 stile rims. F 17X9 R 17x10.5
Nitto 555 tires. F 245/45/17, R 285/40/17
Hydrological E brake handle.
Rear tower brace.
Interior:
Equues Gauges, oil, volt, low band, water, vacuum, Tach.
AEM wide band.
Hurst shifter.
Carbon fiber A pillars.
Carbon fiber two gauge (replacement clock).
Rear seat delete.
Semi Race bucket seats.
Jegs seat brackets.
Summit Racing Battery box in trunk.
Exterior:
Saleen spoiler.
Mach 1 front lip.
2.5 Cowl SVO/cobra R stile hood.
F1 stile carbon fiber mirrors.
other:
I need to get a paint job some day and would like to change the hood, front bumper cover and possibly the spoiler.
Also a seat belt harness bar, Kenny Brown extreme matrix kit.
And I am sure that I'm missing something.
FivepointSlow
Enfield, CT, USA
My car isn't even fully put together and I haven't bought all the parts yet but come spring when I register it this is what it will have..
SVE 130 AMP Alternator
BBK Strut tower brace
Flowmaster axle back exhaust
Drivetrain:
1.7 Pedestal mount roller rockers
CompCams pushrods
Ford Racing Flat Tappet lifters
CompCams Thumpr Flat Tappet Cam stage 1
Trick Flow Valve springs
MSD cap and rotor
MSD coil pack
Ford Racing spark plug wires
NGK spark plugs
SR PerformanceCAI
18"x8" 2012 Mustang GT take-off wheels plasti dipped black w/ chrome center caps and lug nuts
Pirelli 235/50/18 P Zero Nero All season
1" spacer in the backs
Cross drilled and slotted rotors
Ceramic brake pads
SR Performance coil overs
Interior:
Black Reverse glow guages
Most smooth plastic painted Metallic silver
Viper alarm system
Alpine head unit
Dual amp
2 12" subs
Billet air control knobs, headlight knob, rear defroster knob, shifter knob, and pedal covers
35% tint in front
15% tint in back
Exterior:
Black Cobra style headlights
Yellow tinted fogs
99-04 chin spoiler
Black Pony in grill
1996 Cobra hood
03-04 Cobra style wiper arm and blades
No sideskirts
8" shorty antenna
Smoked Raxiom taillights w/ sequential harness
Chrome bumper inserts
How it will be sitting once I get my spacers installed and get coil overs.
Also, the drivers seat POV (getting the door skins and airbag this week...)
And here is a little throwback to the day I got it...
95opal
To many to list lets just say the dash pad is the only thing on the car that hasn't been modded, but Im thinking that may change in the very near future lol
the5.ohh
Shaolin, NY
C&L CAI
C&L 76MM MAF
Ford Racing 9MM Blue Plug Wires
Autolite Iridium Plugs
Starter wrapped with heat wrap
B&D Cap & Rotor
Duralast Gold IAC
Drivetrain:
Stock
B&M Hammer Ratchet Shifter
17x9 Anthracrite Bullitt Wheels
Goodyear Eagle GT's 245/45/17s (SUCKKKKKKK)
KYB Excel GR-2 Shocks & Struts
Akebono Ceramic Brake Pads
Powerslot Slotted Rotors
Interior:
Blue LED Dome Light Bulb
White LED Bulbs behind gauge cluster (lights up blue)
Green Skull Shift Knob
Alpine Deck (ipod, bluetooth, pandora etc)
ARC Audio 4100SE Amplifier
Alpine Speakers (OLD from previous owners, going to get Helix Blue's)
2- JBL 10'' Subwoofers in a custom box for 94-04 Mustangs
Bullitt Pedals
Exterior:
17x9 Anthracrite Bullitt Wheels - Plasti dipped black for the winter, left the center caps, lug nuts and valve stems chrome
Painted my calipers red
99-04 Mach 1 Chin Spoiler
Kaenen S281 Spoiler
Tinted Rear Sidemarkers
Black Housing Cornermarkers
Chrome Turn Signal Bulbs
Black Housing Projector Headlights
Clear Foglights w/ 2500k yellow bulbs (
jdm YO )
New Edge GT Fender Badges (Flat)
No Pony Grille (never going on, its ugly as fack)
35% Window Tint (Want new tint, 20% all around)
Stainless Steel Bumper Letter Inserts
Shorter than stock antenna
Painted rear lower valence gloss black (by me)
SN95FORUMS.COM decal on the 1/4 window
Clear License Plate Light Lens Covers
White LED License Plate Light Bulbs
6000K White LED Reverse Light Bulbs
Exhaust:
MAC Chrome 1- 5/8'' Longtube Headers
BBK Shorty O/R - X Pipe modified to fit MAC LT's
MAC Pro Dumps (Flowpath mufflers)
Added 2.5'' Stainless Steel Tailpipes
Other:
Plans are 96-98 tails with sequentials, Magnaflow 3.5'' exhaust tips, a 1'' drop, rear lower control arms, 4.10s, maybe some motor work idk.
SLOW95GTS
I'll try my best to remember, and ill just post the h/c/I im going with...
Motor
-Edelbrock #60329 stud-mount 170cc 1.90/1.60 aluminum heads
-Svo motorsport Intake manifold/Tmoss ported Lower
-Trick Flow 1.7 Roller Rockers stud-mount
-Steeda #19 cam .480/.480
-O.E Double roller timing chain
-New Fel-pro Head/WP/TC gaskets
-Mr.Gasket 180* thermostat
-New Water pump
-New Stock radiator/New hoses
-Ford racing spark plug wires
-BBK 70mm throttle body
-Sprectre filter
-ARP head bolts
-24lb injectors
-C&l mass air meter
-Aeromotive FPR
Suspension
-Beilstein Struts/Shocks
-Steeda Sport springs
-New sway bar bushings
-Eibach front and rear sway bar
-New rack-n-pinion bushings
-New ball joints
-SVE rear upper and lower control arms
-SVE Sub-frame connectors
-13" cobra brakes w/ 95 cobra hoses
-New ceramic pads all around
-New rotors all around
-Steeda triax shifter
-Stock T5
-ford racing 3.73 gears
-Ram HDX 10.5 clutch
-SVE adj. clutch cable and quadrant
Wheels & Tires
-SVE Black 17x10.5 bullitts w/ 315/35R17 sumitomos
-O.E Ford 17x8 bullitts w/235/45R17 Michelins
-New SVE center caps
-Dorman Chrome lug nuts
Exterior
-Mach 1 chin spoiler
-Smoked headlights
-Cobra R Y2K 3" hood
-Saleen S281 wing
-Black painted tail light Bezels
-Plasti-dipped roof
-20% tint on three back windows
Interior
-03-04 cobra style shifter knob 5-speed pattern
-99 GT shifter bezel
-New JVC cd player/Aux
-98 style center console cup holder conversion
Exhaust
-Svo motorsport headers 1 5/8" primaries
-BBK off-road X pipe
-Dynomax side exhaust kit
More to follow...
Ruddersdhg01
Sportsman block stroked/bored 331 w girdle.
Scat crank and rods clevite bearings
Mahle forged pistons (16cc dish) cr 8:7:1
Gt40x heads Port and polished larger valves 10*locks and retainers
Trick flow roller chain and pushrods.
Fms blue 1.6 rockers
Anderson b31 cam
Systemax upper ported truck lower
Fox TB 75mm Holley tb
V2 s trim blower asp crank pulley with 3.33 pulley
Red race blow off valve
Pro M 80mm blow through
bbrewer2005
Cincinnati, OH
All in a 96 cobra chassis (got it with no drivetrain)
Engine/Underhood/ECU:
-T4MO with twEECer R/T
-306 xxx Block with speedpro forged pistons/rods (stock compression)
-Clevite bearings all around
-All ARP Bolts/Studs
-GT40P heads, light/mild porting. 3avj, all moving parts replaced. Comp dual springs, 1.6 crane energizer RR's
-E303 cam (soon to be Anderson n41, sitting on shelf waiting for warm weather)
-95 "svo" ford motorsport intake, portmatched to heads (completely Identical to the 94/95 cobra intake)
-BBK (edlebrock??) 65mm TB
-24lb Ford injectors/stock MAF
-AC/Smog/Evap/EGR deleted
-MSD 6AL-2 box.
-Professional products FPR
-Walbro 255lph fuel pump
-BBK Longtube headers
-BBK O/R X-pipe
-MAC Produmps
Drivetrain:
-Rebuilt T5 with pro 5.0 shifter
-Ram HD clutch and flywheel
-8.8 rear from a 2001gt
-3.73 frpp gears
-frpp aluminum driveshaft
Suspension:
-UPR K-member
-03/04 cobra front control arms
-Maximum Motorsports Caster/camber plates.
-BMR Adjustable uca/lca with solid bushings.
-SMR torque box reinforcement plates on both upper and lower.
-Eibach sway bar kit, front and rear.
-H&R super sport springs
-Cobra brakes all around
-Prothane bushings everywhere there isnt solid bushings
Tires
18in 2000 Chrome Cobra R replica wheels 9in/10in front/rear
245/35/18 Hankook ventus v12 evo k110 tires up front
295/35/18 BFGoodrich g-force T/A KDW2 in the rear
****Currently I have some 225/55/16 pirelli winter carving edge snow tires on steel wheels, due to the rediculous ohio winter we have been having.
Summer tires going back on very soon. (we got light snow today :/ )
Interior and exterior all stock. Laser red paint with all black leather interior
Audio
JVC Arsenal kd-a95bt headunit
MMATS Pro audio CF61cs front components (6.5) (PITA to make the mids fit with the door panels on)
Diamond audio D671 rear components (ditched the mach box so I could fit my subs. Didnt like the extreme midbass the mach box gives with aftermarket speakers)
Focal FPD 600.1 4ch amp for components (Replaced a kicker 350.4, WOW what a difference.)
2 12in Boston acoustic G3 subwoofers in their own custom ported box. roughly 1.75cu each.
Alpine PDX 1.1000 amp on the subs.
peasant99
