Post your mods!! (V6)
Duffy
Hot Springs, SD
I'm just getting started with mine, decent running and looking vehicle (needs paint)..........found a few interior parts that needed to be replaced. Installed a CAI (eBay one for cheap), cleaned up the throttle body while it was off, installed a Summit Racing cat back exhaust with Turbo mufflers. Looking at getting a rear end (probably a 8.8) with 3.L73 or 4.L10 gears. Found one in a 94' Explorer but I need to verify width and gears (good price $75 if I pull it). Then I will need a tuner to change shift points and adjust for the new gearing. I'm kind of partial to the Diablo Sport 7101. It seems to have good reviews and does what I will need. Just like having another motorcycle, the modding never stops...........:)
SnakeBit!
Florida
2004 3.9L Mustang (son's car)
Engine/under hood/ECU :
bbk cold air kit with mass air meter
Superchips Tune
Mac dual exhaust with h pipe
Drivetrain:
nothing yet
Chassis/wheels/tires:
96 cobra front sway bar
25mm rear sway bar
Caster camber plates.
Urethane front sway bar end link bushings
Urethane front sway bar bushings
Urethane steering rack bushings
Performance friction brake pads front
96 Cobra front brakes coming up.
17x 9 sve black wheels with 255 40 17 tires
17x10.5 sve black wheels with MT 315 35 17 tires
Interior:
white face gauges
upgraded head unit, bluetooth, etc.
SVE race seats
Exterior:
Blacked out rear tail light panel
Satin black rear wing
Black LED third light
black rocker panels (car is red)
blacked out 40th anniversary fender badges
Mach 1 grille delete
Clear fog lights
Mach 1 chin spoiler
other:
Exeter Ontario
I have not completed a lot of mods on my SN95 but here is what I have done. I added a strut tower brace for greater handling. I have added fog lights to the car from a '98 mustang and they went in easily since the car was pre wired at the factory. I just had to add a switch and a relay under the hood. I bought 17" Bullit style wheels off of a 2005. I have 235 50 17's on the rear and 225 50 17's on the front. This is a convertible and it looks pretty good with the updated wheels. I am glad I did the fog light addition. This car is winter stored and has never been out in the winter since I have owned it. I enjoy reading what some of you have done with your cars.
g36 monkey
Orlando, Fl
If you bought wheels off of a 2005 then they have the wrong offset. You will need to get spacers, otherwise they will be tucked into the wheel wells quite a bit. Glad you're having fun with it!
Kyle89
Same way you can get them airbrushed :)
I got my valve covers airbrushed
ENGINE MODIFICATIONS:
· Tuned By Steve at : PowerTrain Dynamics
· V1 Vortech Supercharger pushing 10lbs boost using a custom made 2.90" blower pulley and now over 300rwhp and 310tq+
· 3 Core Custom Intercooler by BTI
· 3 Core Fluidyne Radiator
· Harland Sharp 1.73 Roller Rockers
· Spec Stage II Clutch w/ adjustable quadrant and firewall
· Borla Side Exhaust
· Bassani Custom Bent Offroad X-Pipe (meant for 95 GT, custom bent to V6 headers)
· JBA Chrome Shorty Headers
· SSM Wiseco Forged Pistons / Bore Size 3.8300 @ clearance of .0040, comp. height 1.610
· 1992 Thunderbird Supercoupe Rods with Full Floating Pins
· 1992 Thunderbird Supercoupe Stage II Ported & Polished Heads
- - -> 3-angle Valve Job with Chevy Valves, Comp Cam Springs
· RPM Ported and Polished Lower Intake
· RPM Cut N' Welded Upper Intake Manifold
· 214/225 Redlined Performance Mustangs Camshaft with Comp Cam pushrods
· 56mm BBK Throttle Body
· 80mm Mass Air Flow
· 255 Walbro Fuel Pump
· 42# Ford Fuel Injectors
· ARP Bolts throughout engine
· FRPP 3.73 Gears with Traction Lock
· Autolite Spark Plugs gapped to .033
· 8mm MSD Spark Plug Wires
· Steeda Tri Ax Shifter
SUSPENSION MODIFICATIONS:
· Bilstein Shocks and Struts
· Eibach Pro Kit Springs
· Maximum Motorsport CHROME Caster Camber Plates
· Steeda Lower Control Arms
· FRPP Upper Control Arms
· Jamex G-load Brace
EXTERIOR:
· Custom 2 Tone Red Metallic Mica/ Mercedes Black courtesy of SprayedinLA.com
· Classic Design Concepts Side Scoops
· ABC Exclusive Cobra Front Bumper Lip
· Custom "SHO STNG " License Plates
· Shaved Fender Emblems
· 19" x 8" Front iForged Aero 3 Piece rims, 19" x 10" Rear iForged Aero 3 Piece Rims
· BFGoodrich 295/45/ZR19 Rear Tires and 245/35/ZR19 Front Tires
· Painted Side Mirrors
· Classic Design Concepts Side Exhaust Skirts
· Saleen Rear Bumper Cover
· Saleen S281 Wing
· Exported 1996-1998 Taillights with Sequential effect
· Cervini's Cobra R Hood
· Cobra Front bumper with Cobra fog lights
· Smoked Headlights with 6000K HID Kit
· Smoked Clear Corners
· Billet Aluminum Grille with Pony Cutout
INTERIOR:
· Autometer
· Clock Pod with Water and Oil Guages
· 5" Monster Tachometer with shiftlite
· Dual A-Pillar Pod with Boost Guage Air/Fuel Ratio Guage
· Mustang Script Floor Mats
· MGW Headlight Knob
· MGW A/C Knobs
· MGW Cigarette Lighter
· MGW Coat Hangers
· MGW Turn Signal
· MGW Tilt Lever
· MGW Door Pins
· Custom Instrumental Insert
· Carbon Fiber Instrumental Insert
· Carbon Fiber Emergency Brake Handle
· Carbon Fiber Shifter Bezel, Door bezels, Radio Bezel, Door Panels
· FR500 Carbon Fiber Shift Knob
· Custom Playstation 2 Enclosure Replacing Glovebox
· Custom Leather Seatbelt Pads
· Custom 2 Tone Seats with Custom Embroidery
· Custom shift boot
· Custom ebrake handle
· Custom 2 tone Leather Ebrake boot
· Custom 2 tone Leather Shifter boot
· Custom 2 tone Leather Armrest
ENGINE:
· MGW Triple Chrome Oil Cap and Dipstick Handle
· Powdercoated Candy Apple red Aluminum Fuse Box Cover
· Red Engine Hosing
· Powder Coated Candy Apple Red Valve Covers
· Powder Coated Candy Apple Red Vortech Discharge Tube
· Polished Upper intake, alternator, brackets, pullies and supercharger
· Coolflex Polished Radiator Hoses
· StangWires 8mm Chrome Plug Wires
MODIFICATIONS:
· Alpine IVA-D310 DvD/Cd/Mp3 InDash Unit
· 2 - 10" Kicker L7 Solo Barics
· 2 - 5x7" Infiniti Kappa's
· 2 - 5x7" Pioneers
· 2 - Infiniti Kappa Tweeters
· Hifonics Brutus 1600x1 Amplifier
· Hifonics Zeus 640x4 Amplifier
· Optima Yellow Top Battery
· 4 Guage Monster Cable Wiring
· 1 Farad RF Capacitor
Interior Updates - November 2012 - Up to date I have installed several of the custom fiberglassed and airbrushed panels for ShowStang. In additional we swapped out for some HID headlights as well. Included here is how the interior was gutted for a new black carpet. Still in teh process of getting the final pieces in; including the dash cover. Hope you enjoy!
I love the build I’m eventually wanting to hit these numbers with my 95 3.8 auto because no one builds 3.8s and I wanna keep my 95 v6 because the whole car is sentimental so if you don’t mind me asking what kinda budget would the drivetrain and electronics run on a build like this today?
Canaryonvskf’s
