Rear Quarter Window Issue........
94StewFord
Milwaukee, Wisconsin
My rear quarter window just makes noise and won't roll up! Motor is working, but it makes a knocking sound and won't roll up.
Suggestions????
isn't there a bushing that is known to go out? I never did it so I can't remember for sure but I thought I had seen something about it.
07GtS197
Fort Myers, Fl
There are 3 bushings/plugs in the window motors. I thought that was a panther thing but could be with our cars too.
94StewFord
94StewFord
pretty sure we have them in ours as well
Found this thread...........
Clutch Cargo
Hey 94stewford, no sooner do I post my thread then I see yours, ha! Sounds like we have the exact same issue. Just open my rear right quarter to have a look. It's probably not you motor but the regulator's teeth in the gear. You might have broken off a few and thus it just sits there grinding away not able to catch any teeth to move her.
b1pig
Most likely the plastic "rollers" inside the window motor gear assembly. 3 out of 4 windows on my 94 Vert were doing that when I bought it. I just used some properly sized metal nutserts that I had in my shop. Added a little duct tape around the nutserts to take up slack and to also put a little "give" between the pieces. At least for a little while, anyway.
I cleaned up all the plastic powder that was crunched up in there, greased it up and put it back together. Works like new. Didn't cost me a thing but time. Besides. Any use of duct tape in the repair of a car increases the likelihood that it won't break again. :)
The teeth on the regulator arm are metal. Even though I have seen a photo of them worn/broken on here, I will still say it is exceptionally rare since the plastic bits are the weakest links and I believe Ford put them in there as a wear item. And possibly to act as a sort of "fuse". What I did was the equivalent of wrapping a blown fuse in aluminum foil... I shall accept my consequences.
The pieces in question would be those little cylinder bits in 74409.
94StewFord
94StewFord
Ordered those on Tuesday and they should be here today...... ;)
maillemaker
How did your repair go?
Mine started doing this exact thing today. Motor is making clunking noises and window barely moves.
Clutch Cargo
My fix went fine. I replaced the regulator making sure the one I bought still had all its teeth on both ends. That was my issue. But since I had it open I did replace the little plastic rollers... inexpensive and easy to replace. I would check both. What ended up taking the most time was ensuring when I tightened up the regulator to the glass it would make a waterproof seal when rolled up. I took my time adjusting and eventually got it.
maillemaker
I just ordered a remanufactured regulator assembly from Oreilly for about $70. Figured I could buy the bushings above but want to get the job done tomorrow. Part should be delivered to store this afternoon.
RevJon
