Size for mouth of real 94-95 cobra intake.
95whitevenom
I am thinking about getting a bigger TB. Mainly so I can put on my AFM power pipe and Pro-M 80mm then add nitrous in a couple of weeks.
I was wondering the size of the opening where the TB mounts. Would a 70mm be ok to keep on there till the summer cause I may be upgrading to a Eddy RPMII when I end up getting new alum. TFS-TW heads.
ryclef331
a 70mm is more than enough. Check the match of the two when you put it on. A 70mm throttle body will flow plenty for you more than likely. Just make sure the openings are matched up where the body and intake mate up.
NITROUSINJECTED
WE DID SOME EXPERIMENTING ON MINE EVEN WITH MY MODS AS SEEN IN SIG WE HAD MORE POWER WITH A 70MM OVER A 75MM TB. JUST GETS WAY TO MUCH AIR AND NOT ENOUGH MOTOR FOR IT WITH A 75
95whitevenom
The BBK 70mm should be here on friday!
When I install that I'll also be installing:
Performance Distributors Dyna mod. ignition module
AFM Power Pipe
80mm Pro-m MAF
redripper
close to a stock engine with the the spray 70mm is perfect. if you change the short block and stay NA go with the 75mm. Got the 75 on my dss 331 stroker with afr heads works good im not to sure if you add a power adder other than nitrous
JohnnyOctane
