Sons 89 F250 2wd project
07GtS197
Fort Myers, Fl
He will be staying with the stock cam of this engine we are freshing up. I guess you could say it is a cam upgrade. This engine is from a '96 and is roller cam. Going from the stock '88 flat tappet to roller.
Is he swapping ecu’s too?
96blak54
96blak54
Lawrenceburg Kentucky
We didnt plant to swap ecu. Do you think it needs to be? From my understanding with the original fuel injection based on map sensor readings, all that needs to changed over is the related drive gear on the distributor. But im all ears to suggestions.
07GtS197
Fort Myers, Fl
The fire order is different on the 96. Even though the ecu uses batch fire, it’ll be confused because it’s expecting a cylinder to fire on one bank when it fires on another. At least that’s what I’ve seen doing some research. I’m helping a guy on another forum who swapped a 94 302 into a 91 and is having all kinds of running issues because of the firing order but he refuses to swap the ecu or cam.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Did the trucks and cars have the same firing order differences? I feel like I remember reading the truck kept the same firing order. I am not sure though.
RAU03MACH
NEW MEXICO
i think the cams are same fire orders , also need to be aware of efi cams and none rfi cams
RAU03MACH
NEW MEXICO
Here are the firing orders from both books for a 1996 5.0 Vin "N" 302: 1-5-4-2-6-3-7-8.
Firing order for 1989 ford truck 302 V8
1 2 3 4 5 6 7 8 look on intake manifold for numbers The spark plug firing order is 1- 5 - 4 - 2 - 6 - 3 - 7 - 8 The distributor rotor turns COUNTER CLOCKWISE
07GtS197
Fort Myers, Fl
Couldn’t say. By cars I’m ASSuming you mean panthers, they kept the 154 firing order until 92 when the 4.6 was introduced (town car was 91). But the truck 302 kept the 154 firing order until 94. This is all from research so take it with a grain of salt. I’d still verify firing order just to be safe.
There is a lot of differing info out there but from research, 94-96 F series with the 302 moved to the 13726548 firing order. Older trucks had the 15426378 firing order. I would verify the firing order on the “new” engine just in case.
RAU03MACH
NEW MEXICO
i think ford has 6 different firing orders for the 289 221 260 302 till the 5.0 ho 93
96blak54
96blak54
Hold on gentlemen.....this thread is about 351w engines. Im pretty sure the 351w firing order stayed the same throughout its history. I could be wrong! But pretty sure. Its the 302 that had different firing orders thanks to the use of a 351w camshaft better known as a 5.0L H.O.
Yall help me figure this out. I aint versed enough into the pushrod windors.
07GtS197
Fort Myers, Fl
I use my phone to access the forum so it goes to the newest post I haven’t seen yet. It’s been a while since I’ve seen the op.
96blak54
96blak54
Still tho, would swaping the spark wires and injector harness around aid the camswap firing order differences of 302 to a 5.0l HO ? Seems simple to me
RAU03MACH
NEW MEXICO
Ya the 302 are simple to work on
Wiring is pretty simple
My 88 F150 was nice
Should have kept it
It was very simple to work on
Converted to a holly 600 4 barrel
C6 trans
Simple distributor with a nice flowmaster system
Short bed
shegz67
