Sep 12, 2014 #1 O okiemike New Member Joined Jul 7, 2014 Messages 23 Reaction score 0 what are some thoughts on the two.. say for example if you make 96 mph in 1/4 = approx 300hp and 100mph in 1/4 = 350hp is that about right?
Sep 12, 2014 #2 L lutter94 Well-Known Member Joined Apr 11, 2008 Messages 3,060 Reaction score 172 Location South Dakota a lot more variables than that. If you had 150 hp in a go cart, you could do 100 mph by the end of the line.
Sep 12, 2014 #3 Orange 94 Post Whore SN95 Supporter Joined Oct 21, 2012 Messages 10,855 Reaction score 399 Location Alberta Canada Yeah... Depends on weight, traction, gears and so on.
Sep 12, 2014 #4 RichV Well-Known Member Joined May 6, 2012 Messages 4,230 Reaction score 252 Location CO Weight is the biggest factor. Trap speed will be relatively the same. There are a lot of HP calculators out there and most is just a factor of weight and speed. Some incorporate altitude as well. http://www.competitiondiesel.com/Phil/bg/
Sep 12, 2014 #5 P punched281 Active Member Joined Nov 1, 2013 Messages 866 Reaction score 1 Location Colorado Well, that was depressing. ^
Sep 12, 2014 #6 OP OP O okiemike New Member Joined Jul 7, 2014 Messages 23 Reaction score 0 RichV said: Weight is the biggest factor. Trap speed will be relatively the same. There are a lot of HP calculators out there and most is just a factor of weight and speed. Some incorporate altitude as well. http://www.competitiondiesel.com/Phil/bg/ Click to expand... + Perfect that is what i was looking for!
