Surging Idle- 94 Cobra
What is causing the surge?
  • Vacuum Leak
    Votes: 2 66.7%
  • Idle Air Control
    Votes: 0 0.0%
  • MAF
    Votes: 0 0.0%
  • Tune
    Votes: 1 33.3%
  • Owner (me) did something stupid
    Votes: 0 0.0%
  • Something Else
    Votes: 0 0.0%
  • Total voters
Michael Plummer
Brockton, MA
What does "leaking down and washing the maf" mean?
Leaking down: Water/methanol fluid left in the nylon tubing is sucked out by the engine vacuum and this fluid flows or dribbles in the opposite direction of the engine/throttle plate.
Washing the MAF sensor: Under harder acceleration, the "leaked down fluid" gets picked up and is blown over the MAF sensor. Repeated cycles of this will eventually destroy the MAF sensor.
Fix: Install your Water/Methanol Injection nozzles behind your throttle plate and use a good solenoid close to your nozzles.
I hope that helps
Michael Plummer
oilspill
oilspill
Atlanta, Ga
I hope that helps
Michael Plummer
That’s exactly what I was going to say!! Haha
oilspill
oilspill
Atlanta, Ga
I hope that helps
Michael Plummer
Weird part is I have a solenoid…but it’s in the trunk.
I also replaced the MAF at one point and it still ran like shit.
Michael Plummer
Brockton, MA
Solenoid in the trunk: The engine vacuum pulls the fluid out of the nylon tubing or line length. The bottom line, the solenoid should be placed close to your water/methanol nozzle. In your setup, you should have used two solenoids.
MAF: Once fluid hits the MAF sensor, your car will stumble and buck. The MAF doesn't need to die for it to have a driveability issue. And you could have other issues causing your bad driveability (easy to do when you add parts without a tune or don't know).
I hope this helps
Michael Plummer
oilspill
oilspill
Atlanta, Ga
MAF: Once fluid hits the MAF sensor, your car will stumble and buck. It doesn't need to die for it to have a driveability issue. And you have other issues causing your bad driveability (easy to do when you don't know).
I hope this helps
Michael Plummer
Appreciate the feedback man. You actually sold me this kit back in 2014 as part of a group buy on a different forum. Full circle a decade later after I finally installed it.
ah I see now with the solenoid in the back. Correct me if I am wrong but don't you want the nozzle in front of the AIT sensor?
oilspill
oilspill
Atlanta, Ga
you would....i moved that sensor to the lower intake when i did the blower
oilspill
oilspill
Atlanta, Ga
I hope this helps
Michael Plummer
Michael
Can I use this check valve at the nozzle so I don’t have to run new wiring from rear of car for another solenoid or is that cutting corners?
Been sitting on my desk for 2 years.
mr plumber would be the expert here by all means but if I am thinking about it right I don't think so. It would prevent it from going back to the solenoid but the vac being drawn from the intake would still allow it to pulled out forward. I set up a meth system in my car but I have not filled or used it yet because of one thing or another but I will have to show you how I put my solenoid on the TB. It is a tight fit but it should work.
oilspill
oilspill
Atlanta, Ga
that makes sense. believe the valve has 7psi crack pressure so assume vacuum would open that
I guess i should stop being lazy.
like I said it is a REALLY tight fit but there is just enough room for the TB to move fully and for the nozzle to be there.IMG_20230223_122004154.jpg
Srchop16
