Suspension and tire advice
searay86
I HAVE MADE MY DECISION
Im just going to get the seat time without mods, easier to learn if the cones are coming at me slow right? lolol I'll keep my eyes out on the local marketplace and craigslist.
On a side note, I want to get rid of horrible stock cats with 2 high flow cats and a xpipe.
Pypes and SLP seem to be the options, opinions?
g36 monkey
Orlando, Fl
You may have said it earlier, but do you have to have cats where you live?
I would look for an 8.8 though, better to have a limited slip over the one wheel peel 7.5
searay86
While I am required to have cats because of where I live, I want them so I can stay in my SCCA class where cats are required.
I might be understanding my classes rules wrong but I do not think I can change rearends. And I thought GTs had limited slip? Dang lmao
ReplicaR
Isn't this a GT already? Did I miss something? GT should have 8.8 with lsd from factory
ReplicaR
You can rebuild stock diff, and it doesn't say anything in the rules about using better clutch packs (FRPP)
evilcw311
Most Evil Member!
Louisville, KY
It’s amazing what a difference fresh clutch packs and new fluid and friction additives can make.
searay86
Over the winter the rear end was checked and fluid was replaced :) Id like to do clutch work but thats for future plans
g36 monkey
Orlando, Fl
Gotcha, and I must have just been confused, if it is a GT it is an 8.8, I was thinking of someone with a V6, my bad!
see above lol
They're talking about the clutch packs in the rear end that make the limited slip function.
searay86
Ooooo. As soon as I think I know something theres so much I don't know about my car lol. They could actually be bad in the car. My right rear tire had a lot more wear when I got new tires
searay86
ON A SIDENOTE, last night was fun. Serpentine belt broke then lost power steering and brakes, the whole 9 yards. The belt has gouges in it to where it split. The idler was new last fall and the all the pulleys move freely. Later we put the belt back on and it ran fine. With the belt off, the tensioner looked bent but straight with the belt back on.. ideas??
searay86
g36 monkey and ReplicaR what Koni coilovers did you get? I got the itch to get more car parts :D and ReplicaR should I stick with 9in rims to not worry about offsets/rubbing or advice on 10in rims?
E:10in in the front
ReplicaR
I've got custom valved and shortened Koni dampers and MM Coilovers, about 3k in parts. But my car is also pretty setup and focused. 10 inch wheels won't rub on anything with correct offset (18mm) and enough camber, which mustang needs anyway.
ReplicaR
Same. Fitment is fine too, did this so I could rotate the wheels.
g36 monkey
Orlando, Fl
I have single adjustable Koni struts with an MM setup up front. Non-adjustable Bilstein shocks with MM setup in the rear. ReplicaR is way more competitive than me and would be able to provide the best advice on that topic :)
searay86
Got it! thank you so much for the advice! I'm racing this Saturday and Sunday, I hope the car makes it through :shocked:
RevJon
