Trubble's Build Thread - NITROUS INSTALL!!!!!!
T
TRUUBLE
-Never Forget-
Re: Trubble's Build Thread - NEW PIC!! NEW PIC!! NEW PIC!!!!!!
Hellion94 said:
You probably should weld your axle tubes at some point.. Just noticed that they weren't welded.
They're welded, now. :boink:
Hellion94
Oh, good to hear man. wouldn't want you twistin that thing up.
So, we are a weekend away from starting the blue car, it seems our matchup will be coming far sooner, rather than later.... ^-^
T
TRUUBLE
-Never Forget-
Excellent!!!
Lemme know so I have time to drop the nitrous system in. :boink:
Hellion94
Well, assuming it starts next weekend, which it should, it will be dyno time for break in and initial tuning on Sunday. Then probably the next weekend after that It will get certified probably in Tucson, then the following weeks will be the firs shakedown runs, and probably licensing, sooo I would say sometime next month maybe we would head out there for a weekend.
Eric_94cobra
Thanks for a great read and videos! Glad I poured through all the pages, very impressive. The best of luck to you and your car!
T
TRUUBLE
-Never Forget-
Thanks very much, Eric. O0
So did you ever get your License?
T
TRUUBLE
-Never Forget-
Not yet. I was going to do the final passes in a friend's promod vette but he was having problems with the car.
I'm doing ssome more secret squirrel shit to the car this weekend to see if I can get it from 10.19 into the nines and then maybe I can actually license in my own car . . . lol
I really want to get into the nines on motor. Nothing I have thrown at it seems to make any difference, until I started playing with the fuel trim. Now that I know I'm on to something, I'm going to concentrate on fuel and timing and try to get the 60 foot time down from the current 1.40. I'm also putting a vacuum pump on it and building a carbon fiber scoop tray to force more air into the motor at the big end.
The bottom line is that I need another .29 to be where I need to be. About .39 would be even better.
It'll get there.
scarface
Guest
I have faith in you! :)
T
TRUUBLE
-Never Forget-
Where did the stickies go? :dunno:
scarface
Guest
They were voted to be taken down (all of them, not just yours Tad)
If the thread is popular enough to warrant a sticky it shouldnt have any problems staying at the top.
T
TRUUBLE
-Never Forget-
Update on the motor.
As long as it's apart, we are doing a new cam. Increasing lift from .720 to .800 and maybe giving it a bit more duration.
This will mean that I have to launch a little higher on the 2-step. But, with the 6,000 rpm converter, it should be great down track.
Look for 9.70-9.80 on motor and 8.50ish on spray. :boink:
T
TRUUBLE
-Never Forget-
Re: Trubble's Build Thread - ENGINE UPDATE!!!!!!
I just talked to my builder, who just talked to Comp Cams, and they settled on a cam with .830 on the intake and .798 on the exhaust. Lobe center will change from 108 to 110 and the duration will stay around .278.
might be a little lumpy at idle . . . lol ;D
1996mustangGT
its going to turn over....every 10 seconds :slap:
T
TRUUBLE
-Never Forget-
Yeah . . . but it's gonna rock goin through the traps at 7800 rpm. 8)
Hicks
Nice, Very nice
realitygt
my car would blow up if i put it to 7800 rpms lol
T
TRUUBLE
-Never Forget-
I have my rev limiter set at 8800, but I've never revved it over 8000
realitygt
i know some ricers who can't go that high rofl
RevJon
