Turbo Kit going on the 95 GT.....***PICS INSIDE***
LAFENATU
This is the same DIY kit going on my 1995 GT.
The pics are a 1995 Cobra....my car is next.
Should be enough power to split the block if need be.
8)
scott5
myrtle beach, sc
that looks like a B&G turbo kit.... 70mm Turb.... looks good....
as soon as my dart 331 gets done i can finally get my 61mm turbos started to get mounted. keep us updated.
L
LAFENATU
realitygt said:
the weld on that header looks pretty deformed :santa_undecided:
That was an extra header....this kit is actually the first kit going on a Cobra.
My car is next. :santa_afro:
GaryG
looks awesome man, keep up the good work
quick question: since im gonna do a DIY turbo set up also like urs (but w/ a 76mm turbo), is it better to have the turbo mounted beside the motor (like in the pics) or would i be better off installing it between the motor and radiator?
L
LAFENATU
I would mount it off the header like we did.
If you look at 99% of the kits, even Cartech etc. on the SN95 they mount it either on the driver or passanger side by the motor.
When you say by the Rad - what do you exactly mean maybe I am taking your explanation wrong?
Why are you doing a 76mm? That is fricken huge. A 60 or 66mm will destroy a block if need be...
GaryG
thanks for the info, im want to get into the low-mid 9's on around 20 psi, but turn it down to 10 psi for the street
L
LAFENATU
What kind of motor are you doing this with?
Mid 9's takes A LOT.
I know someone with a Forged 331 R Block, AFR 205's, Victor 5.0 Intake, Ed Curtis Custom Solid Roller, Long tubes, Jesel Rockers etc, and a Vortech YSi and is only doing high 9's and that is in a Fox.
GaryG
ive decided to go w/ a 4v
theres a guy in town w/ a fox that has stock bottom end, lunati cam, tfs tw heads, systemmax intake (iirc), 76mm turbo, c4 w/ 3.55 gears that is running low 10s now, surprised it lasted those runs
heres 2 vids:
Dalamar
SLC, UT
That's cool your doing that yourself. good luck on getting er all put together. :santa_smiley:
Petek
That looks pretty good. I love DIY turbo setups. The only thing i really dont like though is the fact that your mig welding it all together :nonono:
RevJon
