Who needs an alternator relocation bracket?
Lawrenceburg Kentucky
I made a few last night. One pictured was the 1st pc engineered and has a few goofs. Bracket is ment to be universal for 4.6l and 5.4l.
Thats one reason for relocating the alt! Another is front entry intake while still having a stock hood.
The alternator factory location is the worst spot.
OLD H2S
Silver Spring Maryland
I had to flip mine backwards to make room to put a Terminator in a Marauder, they work any way you spin them. It was sitting out like a Vortech running off the normal primary belt. Some people do it to add more than one alternator for big sound systems and rolling ham radio stations.
BMAC96GT
Virginia
My alternator would definitly be going down there if you didnt have to delete A/C. Saw one other company that makes a kit
Other companies do make kits, but are over priced. Ive got some 4.6l/5.4l 2v brackets made and looking like $25ea....something like $30-$35 shipped.
4v 4.6l/5.4l brackets still in development.
Relocating the alt in this location cancels using the hydroboost because of how the belt routes to original alt location then down to the a/c pump location.
However, the positive side is this bracket utilizes the stock alt, opening up a big area in front of the intake.
The negative is only waterpump, crank, alt, and tentioner can be used unless a reverse waterpump can be used (modular design may not be able to) or a idler pulley in around original alt location is used
5.4notch
Hi by any chance do you still make these? I need one for a 5.4 dohc
Notthenow
Anyone ever use 4v alt and brackets for 2v? Would it bolt up? Same reason as Blak, make a center intake with stock hood.
Notthenow
I made this alt bracket because I bought a cops harness for my 98.
RevJon
Staff online
