Window problem ONLY 94-95
A few weeks ago my driver side window wont go down without me pushing it,same thing to go up,but i was able to heard the motor running and a clicking noise so i decided to take the window motor out and surprise the bushing were worn out,so i went to the parts store and bought the bushings and got it fixed now it works like new up and down.now im goign to tell you how and what you need:
Tools needed:
*Bushing can be found at autozone,O'Reillys or Advance auto parts for about $6.99
Part No. is 74410 specs of bushings are :
Diameter:.595"
Height:.429"
*Phillips
*5/16 socket
*Flat scredriver
Step 1: ok first thing open the door (of course)
Step 2: now see the black part that you use to shut the door that needs to come off,on the top of it stick the flat screwdriver
and pop it loose,once that is done puul it straight up, on the back of it there is the power mirror switch unplug it, then
unscrew the two screws to free the lock/unlock harness
Step 3: Take off the two screws that are near the center of the door panel.
Step 4:Now pull the panel door up and then feed the door opening handle thru the door panel.now the door panel is off
Step 5:the window operator i s east of the door,peel back the plastic as necessary to get to it,then unplug it,now fish it thru the
little hole
Step 6:Take the speaker off it has 4 screws
Step 7:now peel back the plastic as necessary to get to the 3 bolts holding the motor
Step 8:takes off the three bolts holding the motor,make sure you are ready to catch it or will fall inside the door (no biggie),get it
out thru the speaker hole.
Step 9:eek:pen the motor by uncrimping the two crimps and pop the cover off surprise !!!!!!all that stuff is not garlic is whats left of
your bushing,at the end of the shaft there is a clip,spread its ears and slide the clip right off (pics no.1)
Step 10: pull the gears out and clean the inside
Step 11:put your new bushings in
reassemble everything and you are done
I hope this helps everyone as it helped me.
NOTE: Passenger is almost same thing
Black97GT
looks like a good write-up! Good job takin the time to do it O0.
yup it took me about 45 mins. i kept having a problem uploading pics to webshots
did you see pics? probably not
Black97GT
nope...just read it, I will check them out when I get home.
x182dan
Ya know if you wanna be cheap or you your local auto parts store doesn't have the bushings you can use nuts. Just put some nuts in there how you would the bushings and it will work fine. I've done it on a few cars. However there is a reason why the stock bushings are plastic so you don't chop your fingers off while rolling the window up.
Dan
Suspect
ATL
cool! thxs man! i just started having problems with my drivers side. now i know what to look for! :thumb:
really? :shocked:
mine have been on there for about
2 years now.
Win
Kennesaw, Ga
Yep just threw in the motor i bought from you so i could rebuild the other one :)
94kingcbra
this happened to my father in law's f-150 too. When I told him what it was he didn't believe me. Until I pulled the motor and showed him...hehe
catch_15
MustangChris said:
why is this problem 94 95 only?
On the other motors, the plate doesn't detach around the gear...it's all one piece, so you can't get into the inside without messing something up.
I did this today on my girlfriend's 95 and it works like a charm. The price of the bushings is up to $9 though.
Still better than a $54 power window motor.
98green5.4
you can also use 1/4 nuts and put them where those little help things go.
did it to both driver and passenger side in my 94 opal car.
427danderson
THANK YOU JAVI! My driver's side window just started acting up like a week ago so yesterday morning I take the door apart thinking it is something simple like the gears not lined up... and everything looked good so I figured I needed a hole new motor... spent some time searching and you have this perfect writeup waiting for me! went to advance and an hour later my window is workin! So thank you my my weekend! :eek:ccasion14:
Mntlkase
beautiful. I just bought my 95 gt and power windows don't work. guy told me it needed window motors and regulators, took shit apart today and saw that was the issue. OUTSTANDING!
muddyman184
My passenger window would barely go up with help and just keep clicking now i don't have to go to the junkyard and take one from a parts car not knowing if that one is broke and my money can go towards another junkyard part lol
gopanoz
I have put six, 1/4 inch nuts in each motor for all windows now on my 94 convertible. Has worked for weeks now. great write up!
FHCee
