For Sale 1997 Ford Mustang GT - Show/Race/Weekend Car
Status
Not open for further replies.
97stanger
So I've been around these forums for a decade now, and the day has come. As most of you know I've been tossing around the idea of selling the car, and I have decided it's come time to part ways. Anybody that has been around these forums knows how much time/money is put into this car and anybody who has seen it in person can vouch that this is probably one of the cleanest sn95's you'll see. Car is located in NJ. All information listed below along with some pictures. I am in no rush to sell this car, and will not even entertain any low ball offers. This car overall is a 9.5/10, for an almost 20 year car with mostly original paint. I am going to try to sell the car "as-is" in the beginning here. If I don't have any luck over time, I will consider pulling engine/trans and trying to sell as a roller and sell engine/trans separately. Please spread the word to any of your car buddies/family looking for a one of a kind sn95 with a ridiculous amounts of time/money into it. Any questions I would be glad to answer, I've owned this car the past 11 years. I have clean title in hand. Asking $15,000 firm as the car sits.
Miles: 52,3xx (original miles on body)
Engine/blower/etc has anywhere from 1,000 - 5,000 miles on it
Car is obviously garage kept and never driven in rain/snow
The good:
Body - near flawless
Paint - Excellent condition. Normal minor things, but would probably have to point out in order for you to notice
Car made 600rwhp through a 2v built auto at 19psi
Have list below of over $30k just in parts and this is off the top of my head
The bad:
Car is down on power. Think it may be a pinched piston ring. I don't have the time or patience anymore to diagnose the issue. Still makes over 400rwhp, but most likely a ring that has to be replaced. Car starts, idles, cruises perfectly fine. A/F ratio is spot on, making 19psi, just down on power currently.
List of modifications off top of my head, and what I paid to show an idea of what is into this car:
Engine
Piston & Ring Kit (Manley Platinum Series 18cc pistons, Manley H-beam rods, ARP 2000 hardware) - $1,300
Cobra Crank - $200
ARP Main Studs - $129
ARP Head Studs - $289
Machine work (Romeo Iron Block .20, Balance Assembly, Align Hone, Clean for Assembly, Install Crank and Check for oil clearance w/in .0025â€, Install Pistons on Rods and check oil clearance w/in .0028â€, Champher & Polish crank, Clearance Block for Crank)- $1,127
Head work (Check Deck surface, Disassemble/Assemble, Set lifter Preload to .040—.045â€, Cam journal clearance between .0025-.003â€) - $395
ARP Cam Bolts - $43.90
Felpro Head gaskets - $104.90
SLP Longtubes (23000) - $719.95
SLP x pipe (23003) - $341.95
SLP Cats (M31040) - $191.95
SLP loudmouth 1 catback - $549.95
I/W 10% overdrive crank pulley - $389.99
Mongoose Kit with power pipe - all powder coated wrinkle black, SCT X-Cal 2 hand held- $3,610
Thump Tensioner (THUMP PM-1004—76) - $375
Kenne Bell Boost a spark (KB89070) - $249
V7 JT trim (VOR 2A159—018) - $2,850
2.85 8 rib pulley - $88
Mondo blow off valve (VOR-8D103-008) - $304
Cloyes Full Kit (CLO—9-3162A) - $524.95
Canton Expansion tank (CAN80—232) - $139.95
Optima Red Top - $219.34
Paxton FMIC - $1,400
Black battery tray (34/78_BM_BLK) - $72
TF Valve Covers (TFS-51811801) - $249.97
Brand new Ford COP’s (DG508) - $303.12
Redmonster COP harness - $150
MMR IAC relocation kit and block off plate (900879, 900877) - $109
AIS triple nozzle 3 gallon trunk kit - $690
Aluminum Moroso power steering reservoir - $95.97
UPR black billet Catch Can (All AN fittings and black line) - $109.99
Brand new PA Performance Black powder coated alternator - $289.99
6061 sheet metal plenum - $275
Accufab 75mm throttle body - $249.99
VMP HPX blow through MAF w/ housing - $300
GI Joe 8 rib kit - $600
Edelbrock Victor Jr. Manifold - port matched - powder coated black - $355
MMR Stage 3 ported PI heads with Crower high lift springs - $1,200
Custom Grind Bullet Racing blower cams (220/230, 533/571, 114lsa) - $600
Transmission
Torque Converter (PI—469618-3) - $1,199
Built 4R70W (Built by Pro Shift Transmission in PA, have original invoice of all work done )- $1,250 for just the rebuild
Trans Cooler (BMM—70297) - $229.95
Interior
Speakers - $239.97
B&M Hammer Shifter (BMM—81001)) - $199.95
UPR A-pillar (PP93004) - $54.95
Clock gauge pod - $43
Z-Series Oil Pressure Gauge (ATM — 2634) - $62.95
Z-Series Water Temp Gauge ( ATM-2635) - $49.95
Z-Series Fuel Pressure Gauge (ATM—2663) - $169.95
Z-Series Boost Gauge - $60
AEM Wideband (30-4100) $169.99
MMR Rear Seat Delete (RSD-9498H-BLK) - $150
Corbeau TRS (CS—S20801PR) $799.99
MM 4 Point Roll Bar (MMRB—6.2) - $329
Wheels/Tires
Front Weld RTS (71MB—504A15A) - $496
Rear Weld RTS (71MB—510A65A) - $570
MT ET Street Radials (275/0/15) - $415
Classic All Season (165/80/15) - $120
Front & Rear Cross Drilled/Slotted Rotors w/ Hawk Pads - $350
Rearend
TF Differential Cover (TFS—8510500) - $154.95
Detroit Truetrac (DTL—913A561) - $435.95
FRPP 3.73 gear - $145
Moser 31 Spline Axles - $260
Suspension
KYB AGX 8 Way adjustable shocks/struts (31001743021, 31000734014) - $419.80
MM C/C plates (MMCC9994-C) - $210
MM Subframes (47001) - $120
Steeda Aluminum Lower rear control arms (555—4501) - $265.95
Steeda HD Adjustable upper control arms (555-4100) - $199.95
Eibach Pro Kit (47010) - $249.99
Welded Torque Boxes
FRPP aluminum driveshaft - $310
Front Steeda X2 Balljoints - $137
MM Steering shaft - $290
Exterior/Dress Up
Cobra Front Bumper - Bought from member on corral
Kaenen S281 Spoiler - $270
Raxiom black Tail lights - $185
Cobra Smoked Fog Lights - $100
2 Piece Smoked Head lights - $150
Carbonware 3†Cowl Hood (out of business) - $450
Redline black hood shocks - $90
Black Radiator Shield - $100
8†Black Shorty Antenna - $15
35% tint all around - $170
Black painted roof, A-pillars, and Hood
Fuel System
Glenns Performance 1000 hp kit (Fuellab FPR) - $1,596.73
SD 60# injectors - $360
Edelbrock Fuel Rails - $120
96blak54
Lawrenceburg Kentucky
Definitely a pretty car. Sorry about your situation. Kinda sad to see you giving up. But their are always more toys to be played with. Good luck man!
97stanger
97stanger
Thanks man, appreciate the nice words. Love the car, but it's time to move on. I'll be back in a mustang soon enough hopefully
97stanger
97stanger
Why dont you bring it to me and we will get you some stainless rings in there!
I considered doing the work, but I'm just exhausted of ripping motors/transmissions/rearends out of this car and I don't even use it.
97stanger
97stanger
Sorry to look like a flake guys, but mods can you remove this
Status
