dannyboy1999
- Joined
- Jul 28, 2024
- Messages
- 14
- Reaction score
- 3
Damn so no lontubes huh ?Any 4v shorty header for a 96-04 cobra or mach 1 will fit but the midpipe will need to be widened and may need to be lengthened.
Unless you can fab a set, no. I’ve seen it done on a 5.4 2v but it was all custom.Damn so no lontubes huh ?
Also any pointers on the the ecu ? Im thinking of buying a mega squirt to really be able to tune everything but is it really gonna be worth it or should i spend money elsewhere on parts and just keep my 2v ecu and tune it ?Fursure thanks . I also recently fully rebuilt my 4r70w with a shift kit in it would the bell house fit ?
Yes all Modular’s have the same bellhousing bolt patterns.Fursure thanks . I also recently fully rebuilt my 4r70w with a shift kit in it would the bell house fit ?
The stock ecu will work with some tuning. The stock gt tune will work fine with a 4v but the extra displacement might need some more tuning.Also any pointers on the the ecu ? Im thinking of buying a mega squirt to really be able to tune everything but is it really gonna be worth it or should i spend money elsewhere on parts and just keep my 2v ecu and tune it ?
You think its worth the money though ? Kmember 300-600$ plus long tubes the cheapest i found were 400$ so for the extra 10 to 20 hp would it be worth it ?An aftermarket k-member will serve you good with headers installed on any modular engine. Headers are a royal pain, especially with the stock kmember. The aftermarket kmember allows more accessible room
Buy used headers on market place. I seem to find a few sets of bassani mid lengths and matching x pipe for 4vs pop up.You think its worth the money though ? Kmember 300-600$ plus long tubes the cheapest i found were 400$ so for the extra 10 to 20 hp would it be worth it ?
Not really worried much about my mid pipe cause my old setup up was straight piped anyway so ill most likely leave it striaght piped for the 5.4 aswellBuy used headers on market place. I seem to find a few sets of bassani mid lengths and matching x pipe for 4vs pop up.
Can always get some bassani mid or bbk long tubes and use a torch and a hammer to make the headers fitNot really worried much about my mid pipe cause my old setup up was straight piped anyway so ill most likely leave it striaght piped for the 5.4 aswell
Gotcha also saw a aussie 290 intake for 750 was thinking of running to make up for the stock exhaust mainfold if i did stocks but i have heard that those intake mainfolds are limited editon to Australia and actually provide alot more power then the U.S Variants. And i 100% agree with the rarity of this swap. Ive only seen 2v or 3v swaps did my research on those as well what im not understanding much is exactly how is it that the 2v 5.4 is rated 330-350lbs torque & 3v 5.4 are rated 330-360 but our 4v is 330 solidDon't even attempt headers in your combo without an aftermarket k-member.
And don't bother with shorty headers compared to long tubes. Shorty headers are a waste of money over stock manifolds compared to long tubes.
Beware of cheap headers, they don't always fit properly and may require some heavy massaging to fit.
BBK for lower end cost fit OK and Kooks for a higher end cost fit better.
As mentioned, your stock ECU is just fine.
Simply have it tuned and you'll be good to go.
The 5.4 is wider and taller than the 4.6.
Your intake manifold choice will dictate what hood you can run.
Example - I have a 5.4 with 4 valve heads in my 98 Saleen.
Even with a 4inch cowl hood, I still had to install 1" spacer blocks between the k-member and the frame to allow the motor to drop enough to clear the hood using my Sullivan intake manifold.
Good luck.
Not alot of 5.4 conversions (especially with 4 valve heads) anymore.
Ryan
The 2v heads produce a lot of low and mid range but they lack up top.the 4v heads have great flow so they make mid to upper range hp. Trust me. You will have plenty of tq like the 2v but more hpGotcha also saw a aussie 290 intake for 750 was thinking of running to make up for the stock exhaust mainfold if i did stocks but i have heard that those intake mainfolds are limited editon to Australia and actually provide alot more power then the U.S Variants. And i 100% agree with the rarity of this swap. Ive only seen 2v or 3v swaps did my research on those as well what im not understanding much is exactly how is it that the 2v 5.4 is rated 330-350lbs torque & 3v 5.4 are rated 330-360 but our 4v is 330 solid
How much are producing whp?The 2v heads produce a lot of low and mid range but they lack up top.the 4v heads have great flow so they make mid to upper range hp. Trust me. You will have plenty of tq like the 2v but more hp
