Someone with more knowledge on that will chime in. I have not swapped from coil and wires to COP.
Also i have a 99 cobra intake manifold i know the 99 cobras and up have the same ports as the mach 1's and my heads are mach 1's heads but since the deck is more wide cause the bigger block does that mean it wont fit and what intake mainfold would fit ?or is their any adapter plates?Someone with more knowledge on that will chime in. I have not swapped from coil and wires to COP.
Adapter plate were made. I remember plates were made for use of a stock 4.6 4v intakes and adapters for a coyote manifold. Keep in mind that is not the same plates. You might get lucky sourcing out a Sullivan 5.4l 4v intake, but you will pay dearly. A sullivan 4.6v version and adapter plates will work too,...or......hear me out....cut the 4.6l sullivan in half and widen it to match the 5.4l, since they are more available and still pricey. Most do the coyote Boss style manifold with their specific adapter plates.
Another route and this method is what folks were doing way back when modulars came out, is the lower navigator manifold and an upper lid off a cobra manifold. The navi intake is huge. Has an upper and lower. People make a plate to mount ontop of the lower navi and adapt a 4.6l cobra manifold lid/throttle mount on to the plate. So you do have some options.
Yeah all i see are 5.4 to 5.0 intake adpaters i cant find the ones i actually need to slap my 99 cobra manifold that i got.
Thank you. I guess they say long time lurker, first time caller.Welcome to the forums Dsmless.
We need you to post some pictures of this setup!I just used a coyote intake manifold with the stock coyote injectors and dbw throttle body ontop of adapter plates for my 5.4 4valve swap. This is into a 70 mustang. Join the 5.4 swap facebook group as I see the adapter plates for 4.6 to 5.4 pop up for sale sometimes
Sure, let me make an introWe need you to post some pictures of this setup!
What kind of compression ratio u looking at ? Cause i have a 5.4 4v that i want to do N/A header, big cams, 302 boss manifold or 18 gt mainfold dont really know what route ima take with the i take but what compression ratios am i looking at ?I just used a coyote intake manifold with the stock coyote injectors and dbw throttle body ontop of adapter plates for my 5.4 4valve swap. This is into a 70 mustang. Join the 5.4 swap facebook group as I see the adapter plates for 4.6 to 5.4 pop up for sale sometimes
Since I used a complete navigator 5.4 its still at the stock 9.5 to 1 ratio. Using a coyote intake will not change the ratio. Im not sure were the comp ratio will end up if you use c port heads but Im sure it will end up closer to 10:1What kind of compression ratio u looking at ? Cause i have a 5.4 4v that i want to do N/A header, big cams, 302 boss manifold or 18 gt mainfold dont really know what route ima take with the i take but what compression ratios am i looking at ?
