EFI to Carb conversion- Mods Sticky please
95 svt cobra
Well since Jason Fletcher's site has been down and who knows for how long ive gotten a nice conversion write up for those thinking about doing it.  For any 5.0 guy from the foxes to 95.  Here it is:
just for the record i did not write this up just passing along useful info...
EFI to Carburetor Conversion
Introduction
This article is for anyone with an '86-'95 Mustang that is contemplating converting from the Electronic Fuel Injection (EFI) to a carburetor.
Why Are You Converting?
The first question you should ask yourself is why. Why do you want to go from fuel injection to carb? If your car is a daily driver that is fairly stock then you are just wasting your time and money. Your gas mileage will decrease, you will lose some low end torque, you will lose some drivability, you will increase your exhaust emissions, and decrease the value of your car. If you have a street/strip car and are looking for a cheaper way to build more power then a carb setup might be for you. If it is a race car and you don't care about drivability then a carb is a smart choice. Don't get me wrong, a good well thought out carbureted combo is a very good system. But if you are switching to a carb just to solve your problems with EFI you might be surprised. A carburetor requires work to get it right. You may be trading in your problems for a whole new set of problems that you know nothing about. Before doing anything carefully weigh out your decision to remove the factory system from your car. In the end I hope that whatever decision you make turns out to be the best for you and your car. GOOD LUCK!!!
Mechanical Changes
Intake and Carburetor: Of course if you are converting from EFI to carb you must have an intake manifold and a carburetor. Just be sure to size the components to match your combination properly. The Building the Perfect Combo article on this website can help.
Fuel System: You will need a new fuel pump and pickup. Do NOT use the existing EFI pump. You can either use an electric low pressure pump designed for a carb (like the Holley red or blue pumps) or go with a mechanical fuel pump. In either case you must replace the fuel pickup on top of the gas tank with a purpose built pickup that does not include an in-tank pump. The Mustang Performance Handbook Vol. 1 includes plans to build your own pickup if you decide not to shell out the $100 that it takes to buy an aftermarket one. If you have a drag car it may be time to upgrade to a fuel cell or modify your existing tank for a bottom sump. At this time I also recommend you go with new fuel line from the tank to the carb. Use 3/8" minimum or larger based on your needs. Remember that many sanctioned race tracks will only allow up to 12" of rubber fuel line so go with aluminum wherever possible, and keep the lines in-between the frame rails for safety. To use a mechanical fuel pump you must change the front timing cover on the engine to one that accepts a bolt-on fuel pump. You may also need a fuel pump eccentric to drive the pump. My '88 motor had one from the factory but I have heard of some roller motors that do not have them.
Ignition: Replace the distributor with one from an '85 manual transmission Mustang. This distributor has a steel gear to be compatible with a roller cam. Also use a Ford Duraspark II ignition box. Follow the Ford Duraspark II Ignition System article on this website to hook it up right. A complete MSD distributor and box could also be used as a step up from the factory stuff.
Brackets & Linkage: Any fox body accelerator linkage will work as long as the car was equipped with a carbureted V8. Look for a '79-'85 V8 Mustang or an '83-'88 V8 T-bird if you go junkyard searching. You will also need the throttle cable bracket attached to the intake manifold and a throttle return spring.
Transmission: This is probably the most critical step of the whole process. If you have a manual transmission you have nothing to worry about. However, if you have an AOD automatic you need a TV (throttle valve) cable. You can purchase this from Lokar Performance (NOTE: this is the same cable that Windsor-Fox Performance carries except $25 cheaper from Lokar direct). Setup is critical so follow the instructions included closely. Setting up the cable wrong will lead to a burned up transmission in very short order.
Electrical Changes
The electrical changes described here are for a 1990 Mustang. All '89-'93 mass air equipped Stangs will be very similar. '86-'88 speed density and '94-'95 mass air Stangs will also be close but some changes will be necessary. The best method to keep the wiring straight is to purchase a Chilton's Manual that includes wiring diagrams. Compare your car's wiring to the 1990 Mustang wiring. By using this outline and the correct wiring diagram the job will be much easier.
Your car is divided into two harnesses; the EEC harness and the main or "chassis" harness. The EEC harness contains all of the computer related sensors, actuators, and such. It also contains some of the wiring for the air bag system. The chassis harness contains everything else; headlights, fuel pump wiring, instrument cluster, etc., etc. In order for the EEC to receive power from the battery, control fuel pump, and the airbag to work properly, the two harnesses must mesh together at some point. There are 4 of these points:
--Two connectors near the computer (passenger-side kick panel). One is green, one is gray. Both are 8-pin connectors I believe. One is rectangular and the other is round.
--Two connectors near the driver's side hood hinge and right above the master cylinder. One is gray, one is black. They are both round, 8-pin connectors. One of the connectors does not utilize all 8 pins.
The first thing to do is the part that's the most fun! LOL Disconnect the battery (of course!). Remove the computer and the EEC Power relay that sits directly above the computer. On the 60-pin connector that plugs into the computer, remove the black plastic "cap" which holds the wire bundle at a 90 degree angle to the connector. Unplug the two 8-pin connectors mentioned above, unscrew the bare wire ground and you should be able to pull the harness up into the engine compartment. The oval-shaped grommet will come with the harness, so use a screwdriver to pop it out of the hole.
Once you've got that done, everything you need to remove is under the hood. Just start at one end of the harness and work your way around and disconnect everything you come to that attaches to the EEC harness. As a minimum, you're going to have to remove the upper intake to get to all this. This should include the following items:
--TAB/TAD solenoids
--EVR solenoid
--MAF meter
--Air Bag connector below MAF
--Round 8-pin connector below MAF
--EVP solenoid
--TPS
--IAC
--All 8 injectors
--Water temp sender
--Oil pressure sender
--TFI module
--ACT
--ECT
--Carbon canister solenoid
--ground at starter solenoid (single pin connector)
--Two connectors located near brake booster
I'm sure I'm forgetting something, but just disconnect everything you come to and the entire EEC harness will pull out. You will be shocked at how much all that copper weighs..LOL
Once you've got everything out, it's time to start re-wiring. All the re-wiring will take place at the two connectors by the brake booster that you unhooked earlier. This is how you will tap into the chassis harness and get things like the fuel pump working again. Best way to accomplish this is to tap into the wires just below the connectors. I use those little plastic splice connectors...works great. Be sure to tape up the open ends of the connectors to prevent water from getting in there.
If you've got a Chiltons with the wiring diagrams in it, I will include the reference numbers for each wire if you'd like to look them up.
On the Gray Harness:
---Wire #16 (red/light green - 16 Ga) to the ignition trigger/turn-on lead. On my MSD it's the thinner red wire.
---Wire #11 (Dark Green/Yellow - 20 Ga) to the negative side of coil or the "tach out" port on an MSD. This is the line to your stock tach.
On the Black Harness:
----GROUND #97 (tan/light green - 18ga) to a suitable chassis ground. This creates the ground for the primary side of the fuel pump relay.
---Wire #39 (red/white 20ga) to the temp sender.
---Wire #31 (white/red 20ga) to the oil pressure sender.
---Wire #361 (red 16ga) to #16 (the wire you ran to the ignition turn-on above). This creates the positive voltage supply for the primary side of the fuel pump relay.
Only other thing that you need to do is when wiring in the fuel pump itself. Just get the polarity right on the two wires that are coming off the stock EFI pump. I cut them and extended them out to where my Holley Blue is.
On the underside of the car, you can disconnect the O2 sensors and oil level sensor (side of oil pan) and pull that harness out too. I didn't mess with it, but you could rewire the oil level sensor to still be operational if you wanted.
After that, you should be good to go! As far as wiring the ignition, you'll have to run wires to the positive side of the battery and chassis ground as well as wire the pickup to the distributor. If you've got an MSD, the diagram can be found at: http://www.msdignition.com
Just in case you didn't know, the smaller the gauge (Ga) of a wire, the bigger around it is. That should help you to distinguish between the right wires. Your fuel level gauge will still work properly (providing you didn't put an old carb tank in the car) and your ammeter should work fine as well.
__________________
7.5spool
Tn
that is probably the best write up on 5.0 swaps ive seen, nice work keep it up :thumbsup:
max5ive8
Troy, Michigan, United States
I have done this. I wouldn't recommend it. My car came with all sorts of problems, ranging from burnt up wiring harnesses to a fuel tank that I had to seal up the top side with JB weld because it had become so corroded the fuel line sheared off while stroking it with a feather. I had the tank sumped and mounted a Holly Blue fuel pump. I used 1/2" aluminum tubing for fuel line, really flexible and easy to maneuver into place. My neighbor had a Weiand Stealth intake manifold for the 351W out of an F150 were were going to drop in so that took care of the intake need. I started out with a used Speed Demon 650 with vacuum secondaries and had issues tuning it so the tuner installed a Holly 800 DP, but in my opinion it was too much carb and the throttle response was slow, (but I didn't have to worry about leaning out at higher RPMs). I had RHS ProAction 180's that I personally ported and polished by hand, and Mac 1 5/8" shorties. Compression was 10.2 : 1 with flat top fly cut pistons. I had a pretty stout cam and made 355 RWHP. Anyway, my point???? I am now, two years later, blessed by the wreckage that is now my neighbor's 94 Cobra and he has since donated a buttload of necessary EFI parts my way. I can't wait to have reliability and tuneability of a computer again! And to make it richer he was saving a brand new crate 351W with AFR heads, Super Victor intake and four-barrel throttle body for eventual swappage into his Cobra. But...a little water on the roadway lubing up his drag radials and the unfortunate consequences combined with his insatiable desire to see this 5.8 beast come alive has destined the mill for my whip. So, not only am I getting a new motor, but also the glorious EFI, wiring harnesses and new fuel tank without a bloody noisy fuel pump mucking up my beautiful exhaust note from the Flowmaster 50's and Prochamber H. :headbang:
but, if you are so inclined, make sure you save as much of the wiring connectors that you can. Use the connectors instead of direct splicing wherever possible.
CobraRGuy
Fremont, CA
That could be on your end because I'm not seeing them.
It's actually the HTML character reference for encoding an apostrophe character by its decimal code point. In other words, 39 decimal is an ASCII apostrophe. I can't see them, but I bet if you look closely they will appear where an apostrophe would be used.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
I think he would have liked your answer 5 years ago when he made the post.
How’d you find this old thread? Lol
CobraRGuy
Fremont, CA
I did a carb swap on my '95 R. Here's a pic. I bought a Billet Specialties (I think) adjustable cable bracket and a Fox cable. You'll have to drill another hole for the second cable mount bolt at the firewall.
I used an external fuel pump (Mallory) and eliminated the internal pump. I would not recommend using a mechanical fuel pump on these cars. I re-plumbed the entire system with Earl's Speed Flex #8 feed and return lines with Speed Seal fittings. I used an MSD billet distributor and HVC box and coil with a Soft Touch Rev Control. I completely eliminated the EFI computer and engine wiring harness. I used a Derale cooling fan controller. The intake is a Victor Jr. single-plane.
Eventually I will convert back to EFI but I'll use a Holley HP EFI controller and a 4bbl throttle body like the Accufab. The primary reason is, of course, driveability. The carb I used is an 830CFM 4150 HP Race and it performs great on the track, but is NOT street friendly. IMG_20180721_133500334.jpg
RedDragon71
Terrell Tx
So happy that you posted this. I’m in the process right now on 94 GT and this is super helpful! Now I can return all these gauges I purchased!
RedDragon71
Terrell Tx
I have had my carb swap complete for months and I love it. My car is set up for autocross and road course but it’s sound so nasty and runs well enough that I’m going to have some fun at the local 8th mile drag strip.
Werecow
Virginia
I'm essentially fixing a efi to carb swap that was done on mine. It was done wrong and I'm having to go back and do it right, PO hacked up the harness, used the mechanical pump off the engine, and just stuck a tube in the place of the original fuel pump in the tank... I replaced the tube with a low pressure fuel pump, traced out the wires and am having to run the pump off of key hot because the part of the harness that would normally control that was hacked out.. Then I've got to use a fuel pressure regulator and gauge under the hood (I've not got to that part yet. But you can check out how and what I've done so far on my build thread Cherry Bomb!!
JohnnyOctane
