Now it is even worse, when I drove it a couple days ago it used to just be sputtering unload and misfiring, so like I said above, I clean that coil that the coolant got into, still nothing. Now what it does is, it sputter and misfire and pop real bad under load, I was on the highway going and the car started to misfire and I kept my foot on the gas, the gas pedal felt as if you had the car shut off and were just pressing the pedal for fun but the car was still on and misfiring, then it would stop and my pedal would feel like it has something to it. Also when i start to come to a complete stop or even just slow enough enough for that matter for example slowing down to take a turn or slowing down and stopping at a red light the car just stalls out but itll start right back up. Im at a loss with what it is doing. I was pulling that code P0320 like I said above so that made me go and get a new crank position sensor and 8 new spark plugs (my old ones were all black on the ends) I would take out the plug wipe it off, put dielectric grease on the inside and plug
It down to my new spark plugs, I did them one by one to ensure I didnt mess up the firing order. My one friends dad suggested a bad ground while my other friend suggested a bad fuel pump. What do you guys think is causing this?
