Highlighted posts from Wednesday, Feb. 16, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 15, 2022 * 16 posts * 90 views
Snorky said: Yeah, i did get a good deal, i wisu i had spent 3 times more for a better engine though, but i digress these things snowball out of control no matter what you do. You will see ... Read more >>
February 15, 2022 * 10 posts * 43 views
TTSaleen said: When I bought my 2003 Cobra a few years ago, it did the same thing. I ended up resealing the entire surround of the metal where the trunk and quarter panels merge. Basically I ... Read more >>
February 15, 2022 * 6 posts * 48 views
Daryl said: "How to Super Clean your engine bay" by Chrisfix... is the YouTube video. He uses soap/water in a spray bottle + a lot of brushes, microfiber towels, etc. He used a non-flammable ... Read more >>
February 15, 2022 * 18 posts * 192 views
KVacek said: It was called ethyl because the antiknock additive was tetraethyl lead, most prominently manufactured by Ethyl Corporation [link] Read more >>
February 15, 2022 * 15 posts * 224 views
badass98svt said: The SEM Landau Black is spot on for the black in 94-98s. When prepped well, it sticks very good and last a long time. I've used it on a few pieces, such as a steering column gauge ... Read more >>
February 16, 2022 * 3 posts * 19 views
Booboo said: 1997 GT Convertible. Any idea what this plastic tubing is, it has a wire in it. Behind the back seat. [image] Read more >>
February 15, 2022 * 39 posts * 326 views
RAU03MACH said: the corner lights can be a pain once and a while, the Maine reason is the black seal at the top filling the gap then adjusting it to the headlight is a pain main reason i have ... Read more >>
February 16, 2022 * 2 posts * 18 views
white95 said: Very soon I will be switching to a set of Enkie RS05RR with BFG Rival S 1.5's [image] My current Forgestar F14 and Federal RS-Pro setup. [image] Read more >>
February 15, 2022 * 2 posts * 11 views
302N20 said: Race Star 92-510152DP 2 - 15"x10" rear wheels only(no tires) 5x4.5" Ford bolt pattern. 6.5" backspacing Wheels are in good condition, no damage to them. Wheels include center caps ... Read more >>
February 15, 2022 * 4 posts * 119 views
Daryl said: FWIW, I'm running Bassani headers (came with the car), all 4 cats, x-pipe, and end of month will be replacing cat back with the FlowMaster Thunder Series 44. Will also be installing ... Read more >>
Continue reading...
jd96gt
