Mechanical water temp gauge installation
Daryl
SoCal
Is this the correct port to install the new gauge?
Daryl
Daryl
SoCal
Excellent! Easy to get to
Daryl
Daryl
SoCal
Guppa goffee and away I go
Daryl
Daryl
SoCal
… and we’re again at a stopping point. Red adapter too big; had to order #2263 AutoMeter adapter. Shit! Here tomorrow via Amazon Prime.
Daryl
Daryl
SoCal
You could probably find a brass reducer at the local hardware store.
I actually found a set of 4, various sizes, @ VatoZone, but after reading the reviews, I opted to wait a day, spend the extra whopping $2and get the AutoMeter one for qualities sake!
Daryl
Daryl
SoCal
Just got delivered, so a little too late to start in on today. So, tomorrow or Tuesday as schedule allows
Daryl
Daryl
SoCal
Ooh, shocker…. another stopping point! Need a 7/8” hole saw. Pick it up tomorrow @ Home Depot. Errrrrgh!!
Daryl
Daryl
SoCal
Where’s a good spot to drill the 7/8” hole in the firewall?? Has anyone done this and/or have pics??
Thanks!!!
Daryl
Daryl
SoCal
Is the (supplied) black plastic mounting bracket always used on the gauge bezel?
Never mind, got it!
95opal
Thanks!!!
That will depend on were on the dash your gauge is going and how you want to route the temp probe wire.
The plastic bracket is what keeps the gauge mounted tight in its location.
Daryl
Daryl
SoCal
I’ve mounted it under the headlight switch
95opal
May want to try and run it threw the main harness hole in the fender well.
Daryl
Daryl
SoCal
Is this a viable candidate? It feels like a smooshed grommet (?) that at least I could get to with the hole saw. Just not sure what, if anything, is on the other side of the firewall??
Daryl
Daryl
SoCal
I got the bracket in. A bit tenuous because I was afraid of cracking the bezel as I finessed it into place. But it’s in place and no mishaps
Daryl
Daryl
SoCal
3/8” adapter’s in…
How should I route the cable from firewall to the water neck? Instructions urge you to stay away from direct heat and moving parts of course, but what’s best and looks “proper”??
you can just run it next to the injector harness with some wire ties, under the upper intake. Bonus points are awarded for covering it in some kind of protective tubing/techflex/convolute plastic tubing for neatness and just a little more protection
Daryl
Daryl
SoCal
I’m looking for a place that would be “safe” to punch through with the hole saw. I located a potential spot left of the brake booster at about the 9:00 o’clock position. To the touch it feels like an old grommet kind of material or some kind of seam sealer and I can get a drill in there. close-up and pull back pics attached.
Does anyone recognize this spot and is it safe to drill the hole there without hitting something on the interior side?
This is pretty important so many thanks!
you can probably run it through the factory grommet that all the stock wiring goes through as there was always plenty of room for me to run a 4 awg amp power wire through them when I was installing. Otherwise when it comes time to drill you just need to find a spot that you can see on both sides. Say it is 3" to the right of the brake cable on one side, look 3" to the left on the other side to see if it is clear. It is also helpful to make a small hole first and then you can shine a light through it to ensure it is where you want it. Small holes are much easier to fill/fix if it is off a bit than big holes. I normally do a small hole first and then use a stepper bit for the larger.
Whiplash-Smile
