Tall valve covers hit alternator
cameron57
Hi guys in the process of putting my 94 gt back together. Just did hci swap. Running in to some issues with my new tall valve covers. The alternator has a nipple on the back that hits. Is there a slim case alternator that anyone knows of that will fit without grinding? If not can what is the nipple on the back of the alternator can i cut it off
Thanks,
Cameron
Sent from my HTC One using Tapatalk
95opal
either grind a little off the valve cover... or dimple it if you can... or place a small washer behind the ALT mounting points don't worry your belt will be fine...
Musturd
I went a different route . I've got a fox supercharger assembly and march brackets for the rest
cameron57
cameron57
Thanks guys ive got a on3 kit that is next on the install list after i get the tranny built. But i just am ready to drive this thing again lol. I will try opals way if not i guess ill be buying a bracket of some sort.
Musturd
The valve covers that clear are big money , it's very easy to get them to clear , I had mid rise trickflows on my old setup
Suspect
ATL
I took some off the back of the alternator. running frpp vc's. never had a problem.
yes the fox's fit but you need to cut the baffles out of it to hopefully have enough clearance for the rockers under it. The set I have is a polished stamped steel set that I am about to replace. How fast do you need them?
ProKiller
PA
i got moroso fabricated valve covers for the 94-95s. big money but they sure are purrdy
Boosted94vert
