oooooooooooooooooooooooooooooooooooooooooooohhhhhhhhhhhhhhhhhhhhhhhh. Sorry I see now. I have been seeing those online for a while now and wanted to try them when I came across them at a large hot rod swap meet we have locally(largest in the midwest). It is high temp shrink wrap with a ring of solder in the middle and some glue on the ends. So you put it on one wire, inline twist them together and then slide the connector down on splice. When you take a heat gun you can see the solder melt into the wires to make the connection as the heatshrink gets smaller and the glue seals the ends. I can say from the install side that they were super easy, now if they last that is the real question. A quick online search for "heat shrink solder connectors" came up with a bunch of options.
