For Sale 1996 Black and Black SVT Cobra Mustang
SnakeBit!
Florida
$8500
Engine: top end rebuilt with all Ford parts about 23K ago at a professional shop. guides, chains, gaskets, gears, cams, all new.
4.6 DOHC
Comp Cams 106100’s
JLT Ram Air kit
Oil Cooler delete
EGR delete
Steeda Underdrive Damper
March Underdrive Water Pump Pulley
Ramsey Performance Custom Tune with SCT Tuner
Optima Battery, red top
Transmission/Driveline
T-45
Pro 5.0 Shifter with Hurst pistol grip shift handle
FRPP Aluminum Driveshaft
FRPP 3.73 gears (when gears installed, all new wheel bearings, seals, etc.)
Perfect Launch Differential Cover
King Cobra 11" clutch
Suspension/Brakes:
Eibach Lowering Springs
Steeda Rear Lower Control Arms
Koni STrT Shocks/Struts
Maximum Motorsports Panhard Bar
Steeda HD Front Sway bar
25MM rear sway bar
BBK Full Length Sub Frame Connectors
Energy Suspension Front sway bar and sway bar end link bushings
Custom Rear Shock Tower Brace
Slotted Front rotors
EBC Red Stuff pads for all 4 brakes
Wheels/Tires
Black Cobra R Rims
17 x 9 front with 255x 40 x 17 tires
17 x 10.5 rear with 335 x 35 x 17 tires
Gorilla steel Lug Nuts
Extended front wheel studs
Exhaust
JBA Coated Shorty Headers
BBK O/R H pipe
Bassani pipes with Flowmaster Super 44 Mufflers
Interior
03-04 Cobra Seats
03-04 Cobra Steering Wheel
02 Center Console with cup holders
Summitt Racing Tach with Shift Light
3 point bolt in roll bar
AEM wide band air/fuel gauge
Summitt Racing Water Temp gauge
Hurst Pistol Grip Shift Knob
Bluetooth, double din radio with gps and rear backup camera.
Custom Made SVT Cobra ID badge
Snake Emblems on Door Panels
Polished A/C knobs.
Bullitt/Mach 1 pedal covers
Carbon Fiber Console Lid Cover
Carbon Fiber Gauge Panel
Gentex rear view mirror with compass and temperature read out.
All dash lights are blue LED's and the non digital gauges are also blue lighting.
Appearance
2000 Cobra R Style Hood
Saleen S281 Fiberglass Rear Spoiler
Color Matched Ford Trunk Emblem
GT500 Black Snake Emblems
Custom made Snake Wheel Center Caps
Black SVT Cobra Trunk Emblem
Black Cobra Fuel Door
Aftermarket Fog lights with Day running light with turn signal lights on.
HID Headlights
Hood, roof and rear spoiler wrapped in black snake wrap.
Custom outside mirrors.
Sequential tailights with modified flasher for slower rate.
Raxiom dark tinted taillights.
Xenon side scoops
Cobra stencil letters on the back bumper cover.
probably more but can't think of it now. Car never raced, driven hard or even a burn out. Adult owned, maintained and operated. used for DD duty and for car shows. car driven less than 3k last year. Car can be driven anywhere right now. Garage kept since I owned if for the last 8 years.
oil changed every 3k or less. motorcraft filters and Mobil 1 full syn oil only. About 130k on the car, about 23k on the upper engine rebuild.
Everything works, heat, cold a/c, power windows, door locks, etc.
car will come with some extra parts which will include brand new moog front lower control arms with ball joints, new moog tie rod ends, extra set of used Accel coil packs, used set of 10mm red Taylor spark plug wires and two new TMI vinyl and suede with logo front terminator seat covers. Car does not need the front suspension components now but I was planning on replacing them anyway. tuner will go with the car along with a bra for the front.
Car is sold as is, no warranty expressed or implied. Shipping is the responsibility of the buyer. thanks.
Cash or certified check
laramik
Confused at this? Picture links aren't working OP. Try using imgur to host em
Sent from my SM-G970U1 using Tapatalk
96blak54
In the shop
Hopefully he is only "testing waters"
Sent from my SM-G900P using Tapatalk
SnakeBit!
SnakeBit!
Florida
pics show up and open fine for me. not sure what is going on if others cannot see them. not testing...selling the car.
jeanfltns01
