96-97 MUSTANG KEY PROGRAMMING (MAYBE 98)
This instruction will work only for vehicles made from 1996 to 1998 only the following vehicles
1996 1997 ford Mustang
Originate New Master Key
1. Insert new key into ignition cylinder and turn it to the ON (RUN) position.
The security light on the dash will flash for fifteen minutes.
2. When the security light stops flashing, you have five minutes to start the
next step. Turn the ignition cylinder OFF and then back to the ON (RUN)
position. The security light on the dash will flash for fifteen more
minutes.
3. When the security light stops flashing, you have five minutes to start the
next step. Turn the ignition cylinder to OFF and then back to the ON (RUN)
position. The security light on the dash will flash for fifteen more minutes.
4. After the security light stops flashing the third time, the new key has been
programmed into the vehicles computer and will operate the car. It has
replaced ALL the previous electronic key codes and is the ONLY key programmed
into the vehicle’s computer.
Add Duplicate Key
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within fifteen seconds, insert the new key
and turn it to ON (RUN).
4. The security light will light up for two seconds to indicate success in programming
the key into the vehicle.
RevJon
