AC Compressor won't stay on
07GtS197
Fort Myers, Fl
Ah I forgot to mention that.
When the compressor is running it drops down to about 50 in the low side. I forgot what the high side says but I will have some free time tomorrow to get a better reading
That’s the only reading that matters. 50 psi isn’t bad depending on the ambient temps but seems high. Get a sold low and and high side reading and let us know. Also the ambient temp.
O
Oakway9092
Alright so I did a bit of monkeying around on the car:
Without any switches jumped: the reading was at 56psi
With both hi and low switches jumped: it dropped a bit more to 52psi and the compressor ran about a second longer.
Both times only the compressor cycled once and stopped
Car currently has 2 full cans of freon in the system.
07GtS197
Fort Myers, Fl
You only have to jump the low pressure switch to get the compressor to cycle. And you need to get a reading from both the low and high side. Without those numbers and no ambient temp, we can’t help you.
O
Oakway9092
Alrighty I'll try that tomorrow after work
O
Oakway9092
How are you jumping the low pressure switch?
With a paper clip. I have it set to Max AC inside and I hook up the paper clip to the low pressure connector. The clutch engages on for about 3 seconds and clicks off and stays like that while the fan is still running.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Do you have a multimeter? Can you check voltage going to that low pressure switch?
O
Oakway9092
I do have one, I just need to look for it. Do I check both terminals of the low pressure switch?
lwarrior1016
South Mississippi
Only one side of the harness will show voltage. It won’t go to the other side until it’s plugged in to the switch (or jumped), then it’ll go to and through the high pressure switch and down to the compressor.
O
Oakway9092
Ah gotcha, so you want me to check it while jumped?
O
Oakway9092
I set it to 20DCV and no juice. Just 0.00
Update: stupid me had the switch pointing the wrong way. The Blue/Yellow wire its at 0.00 and the Purple Wire I get 0.04. (When set to Max/AC)
RevJon
