Advice on swapping cig lighter for flush mount USB charger
Slice
Toronto Canada
Hi guys n gals. I pulled my shifter surround out because I want to remove the cigarette lighter and install a flush mount USB charger. I do not want one that pushes into the cigarette lighter because then the little flip cover will no longer work. Also there is very little room for the flange so I'm wondering if anybody has done this before and where did they get their flush mount in dash USB charger? I'm thinking I might have to look at a marine supplier because they sell a lot of stuff that you can Dash Mount flush. Photos attached for reference. Thanks in advance!20230328_140156.jpg
the lighter assembly just unscrews. Stick your thumb in in and then twist the back and it comes right out.
badass98svt
Yes, I replaced mine with a dual USB.
I also replaced the one inside the center console with a dual USB. That one is wired directly to the 2 USB outputs on the radio I have.
Definitely lots on Amazon
Slice
Slice
Toronto Canada
I know how to undo a cigarette lighter for replacement. My question is which USB ports will fit under the flip Hideaway cover because I like that feature. I'm concerned some may be a little chunky and you won't be able to close the little lid cover. This is the one that's up by the shift lever.
Slice
Slice
Toronto Canada
Or is it possible that the cheap Amazon push in ones will push in far enough to close the little lid?
badass98svt
Anything like this will fit. Just pull the cover off that comes with the USB adapter.
Quick Charge 3.0 Dual USB Charger Socket, Qidoe Waterproof 12V USB Outlet 36W Dual QC3.0 USB Power Socket with Touch Switch DIY Car USB Port for Car Boat Marine RV Motorcycle Bus Truck Golf Cart etc https://a.co/d/3kPqdG1
Slice
Slice
Toronto Canada
Maybe... but there is only about 1/10 inch clearance when you flip the little lid closed. That's not very much.
badass98svt
Ok, well you have all the information you asked for, hopefully you can figure it out.
Slice
Slice
Toronto Canada
I have the front console surround out of the car. Might as well take it with me to some bricks and mortar stores to check clearance.
badass98svt
I’m actually doing this soon and will probably cheat off of what you guys come up with here.
This is similar to what I used for the radio's USB inputs.
GOBGOD Double Port USB 3.0 Car Mount Flush Cable, USB3.0 Male to Female Car Mount Extension Cable for Car Motorcycle Boat Dashboard Panel 3ft https://a.co/d/6JQDBLv
Slice
Slice
Toronto Canada
That socket looks like it has a male USB cable at the other end. How would this connect to the spade end connectors inside the upper shift console? It sort of looks like an extension cord.
cobrajeff96
Germany
You can find ones that have different input terminations. There's all kinds of options out there. They even have ones with capacitive soft touch power switches on their faces to enable the USB ports, backlit and everything. Fitting behind the shifter bezel cover might be a challenge though. I chose to leave that one as a traditional cig lighter port while the other cig lighter in the center console got the USB ports.
there is a brace behind it that can get in the way but the lighter assembly itself hangs down 2-3" behind it so there is at least that much space.
lutter94
South Dakota
I'm with 95% confidence this would fit under the cover
USB C Car Charger Adapter, AINOPE 72W USB C Car Faster Charger with Mini and All-Metal Body, PD 36W & QC 36W Type C Car Charger Compatible with Magsafe Car Mount, iPhone 14/13/12, iPad Pro, PPS 25W https://a.co/d/23W6Ncr
white95
Apex Junky
Admin
Prairieville, LA
Got thinking about it and I wanted to put an USB plug there for my older radio. This is what I bought awhile ago:
That was before I found a universal Bluetooth adapter that worked with my radios aux input. Now I’m thinking about deleting the radio to save a few pounds.
badass98svt
It doesn't, read what I wrote. It connects to an aftermarket radio.
The first one I linked is for the shifter console.
lutter94
South Dakota
This is the linked amazon charger above.....Phones evolve, and charge faster all the time, I'd hate to limit myself to whatever wattage I hardwire into a permanent USB port. This thing charges "Super Fast". lol
JAR_19
