Highlighted posts from Thursday, Jul. 28, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 27, 2022 * 31 posts * 196 views
Procharged87 said: Kenwood or Pioneer if you care about firmware updates. The Kenwood you selected was a good choice. Unless a product hits the shelves and it's perfect, you may or, more likely, ... Read more >>
July 27, 2022 * 4 posts * 27 views
sn95slobrah said: Hey guys, another question, i LOVE forums and will be asking a bunch. My books says that the 1994 driver side air bag only fits that one year, is that true ?? Read more >>
July 28, 2022 * 7 posts * 67 views
ttocs said: it got bent in shipping then. They ship them in just those plastic bags and I have had 2 that came in like that. I was able to use a heat gun to heat it up and bend it back into ... Read more >>
July 27, 2022 * 5 posts * 26 views
scca vette said: I looked through the threads and was unable to find anybody that has posted the wiring diagram for the MACH 460 AMPS that are located on the rear package tray box. I am trying ... Read more >>
July 27, 2022 * 3 posts * 22 views
LavaSurfer said: Trying to find the plastic guide for the front window rail. From what I can tell that is included in with the entire door glass assembly. Have anyone had any luck finding these ... Read more >>
July 27, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Help me pick a receiver! July 26, 2022 * 23 posts * 100 views Electrical & Stereo Help Battery gauge and abk light on July 26, 2022 ... Read more >>
July 27, 2022 * 14 posts * 197 views
MyBoxersSayJoe said: I'm on RockAuto, which clutch would you recommend going with? I see both Veleo and Motorcraft on there. Willing to upgrade if it's worth it, because after this I'm going to start ... Read more >>
July 28, 2022 * 50 posts * 480 views
Venompower said: I think the best explanation for how to adjust was a video I found of a Mach 1. When they started the vehicle the ToB was chirping a little, and while idling the advice was the ... Read more >>
July 27, 2022 * 5 posts * 72 views
JDMac34 said: A little bit of a late update here: I ended up modifying the cap like I mentioned in the first post and flushed the system with new fluid, and it seems like it fixed my issues! ... Read more >>
July 27, 2022 * 35 posts * 740 views
Warhorse Racing said: I'm a big proponent of experimenting and testing, so it's worth seeing how your car feels with the larger front sway bar. If you have access to a larger rear sway bar to test, ... Read more >>
Continue reading...
Fl510
