Highlighted posts from Thursday, Jul. 14, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 14, 2022 * 12 posts * 75 views
Buffalo5Spd said: Did you put a pressure gauge on it when you changed the regulator? Is that regulator adjustable? What ttocs said is relevant for sure in order to eliminate possible causes and ... Read more >>
July 13, 2022 * 15 posts * 76 views
ttocs said: the tweeter "amp" is under the radio. I put quotes around it as its more of a cross over that just splits the deck power out to the tweeters, then to the sub amps in the back. ... Read more >>
July 13, 2022 * 12 posts * 145 views
ttocs said: a lot of people mistake wd40 for oil. It has some oil in it but it is actually a solvent. It is great for cleaning things, and there is a little bit of oil left over but it really ... Read more >>
July 14, 2022 * 5 posts * 17 views
Snorky said: Anyone know if aftermarket air conditioning lines are any good? Or should i hunt for oem or cars being parted out? Read more >>
July 13, 2022 * 3 posts * 20 views
dwcopple said: Thinking of some Testors granite metallic possibly lightened with some silver if necessary. $2/bottle. Anyone know a better match? Read more >>
July 13, 2022 * 4 posts * 109 views
Wood's 5.0 said: Have you checked your cooler lines? One could be cracked and spraying a bit on the exhaust or a fitting could be loose. Read more >>
July 13, 2022 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Think my clutch is starting to go (MT) July 12, 2022 * 4 posts * 27 views Drivetrain Door locks inconsistent July 13, 2022 * 8 posts ... Read more >>
July 13, 2022 * 81 posts * 3,409 views
ttocs said: I wouldn't sell it if I didn't think it would hold, I am not that kind of guy. Its just a matter of getting to the orings that is kind of a pain in the ass as you have to carefully ... Read more >>
Continue reading...
