Highlighted posts from Tuesday, Jul. 26, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 25, 2022 * 14 posts * 113 views
JDMac34 said: Yep, that's normal. I found this very annoying so I added the Maximum Motorsports clutch relocation brackets, quadrant, and adjustable cable. My clutch is now even with the brake ... Read more >>
July 25, 2022 * 10 posts * 35 views
Venompower said: So, in an effort to do this in pieces and based on my factory Stereo/Tap and CD decks being junk... I'm going to tackle the audio in a modular fashion. I've decided to start with ... Read more >>
July 25, 2022 * 17 posts * 137 views
i86hotdogs said: I'll send you my handle and knob if you send me yours :) shipping should be the same between the two. edit: just realized you have a new edge. Not sure if my '98's shifter is the ... Read more >>
July 26, 2022 * 13 posts * 61 views
ttocs said: blown fuses. I know it sounds like a lot of work but it literally takes about 3 mins to physically pull and inspect every fuse in the car and with any electronic problem you should ... Read more >>
July 25, 2022 * 8 posts * 38 views
ttocs said: see I am just not so sure if I actually remember seeing one of those or not just because it was one of those moments when I saw it I knew exactly what it was because of my time ... Read more >>
July 26, 2022 * 2 posts * 13 views
b1pig said: .... Not that.... Get your mind outta the gutter. Seriously. The speedometer in this car sticks. It seriously hangs up between 45-65. I've got video of it. Debating on uploading ... Read more >>
July 26, 2022 * 32 posts * 359 views
robster94gt said: Ok, so in the rear, I'm thinking maybe a less expensive pair- I've read that the rears don't have be as good as the front. And for sub, I'm hoping that a compact/flat 8 or 10 inch ... Read more >>
July 25, 2022 * 1 post * 9 views
Frank.JD.Perez said: Hey Guys, looking to see if anyone has an 94/95 spindle knuckle(s) laying around from a swap. just need one for a project, but ill take both if theyre taking up space. lmk! Read more >>
SN95Newsletter said: Click here to view on the web Highlighted posts Pedals staggered this much?? July 25, 2022 * 12 posts * 64 views 94-95 5.0 - Specific Cooling fan July 24, 2022 * 15 posts * 102 ... Read more >>
July 26, 2022 * 9 posts * 206 views
tmwsccsh said: I went through a similar experience a few years ago (there's a thread on it on here somewhere...). In the end I found a complete system on ebay, head unit and cd player and the ... Read more >>
Continue reading...
jonathanlenry
