Highlighted posts from Wednesday, Jul. 27, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 26, 2022 * 23 posts * 100 views
Venompower said: Thanks everyone for the suggestions. I ended up ordering the Kenwood last night, discovered the Kenwood had a capacitive screen and the Sony did not. That was worth the extra money ... Read more >>
July 26, 2022 * 33 posts * 122 views
b1pig said: If your voltage gauge pegs at 18, I assure you the alternator itself is probably fine. The regulator does what it's name is... it regulates the current from the alternator to the ... Read more >>
July 26, 2022 * 18 posts * 159 views
badass98svt said: More like under 2 hours. Hardest part is wedging yourself under the dash to remove/install the quadrant. Someone on here just had a bunch of issues installing a new cable and quad. ... Read more >>
July 26, 2022 * 9 posts * 48 views
Daryl said: Found them (Dorman kit)on Amazon Prime for $3.75 including tax! Will pick up this afternoon at Amazon Fresh near my house. Read more >>
July 26, 2022 * 3 posts * 38 views
Rocco_Roush said: 2002 Roush stage 2 but its just the GT 4.6, motorcraft filter FL-820-S. Does the filter always stick out further in diameter than the housing? Only my second oil change since i've ... Read more >>
July 26, 2022 * 17 posts * 132 views
TTSaleen said: No problem. Yes when the compressor is off, the low side will rise and that is perfectly normal. As I mentioned, here's my updated video of the switch I had to replace. [link] Read more >>
July 26, 2022 * 4 posts * 34 views
Daryl said: Since it's unlikely anyone will want to buy these without the tabs, maybe I'll take a shot at some light sanding and repainting with a satin spray paint? They fit better than the ... Read more >>
July 26, 2022 * 7 posts * 75 views
b1pig said: You could experiment before committing to paint with some wrap. You can peel it off and paint it after you decide. I've had personal experience with gloss, flat and satin blacks. ... Read more >>
July 26, 2022 * 1 post * 15 views
SN95Newsletter said: Click here to view on the web Highlighted posts Pedals staggered this much?? July 25, 2022 * 14 posts * 113 views 94-95 5.0 - Specific Help me pick a receiver! July 25, 2022 * ... Read more >>
July 26, 2022 * 39 posts * 392 views
ttocs said: mainly because you are now planning putting both the amp and a small sub enclosure where the amps. There isn't much space back there and the powered subs offer more prepackaged ... Read more >>
Continue reading...
Sn95tre
