Highlighted posts from Wednesday, Jul. 13, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 12, 2022 * 4 posts * 27 views
MyBoxersSayJoe said: I'm at 114k miles. On the highway in fifth, if I hit the gas the RPM's kind of jump up, but the speed of the car gradually increases then catches up to it. Is there any specific ... Read more >>
July 13, 2022 * 8 posts * 117 views
Daryl said: Ah, hell ! Driver side not working again. Worked fine couple times, but now back to Square One :-( When I push the lock/unlock button, it actuates but the door lock knob doesn't ... Read more >>
July 13, 2022 * 4 posts * 10 views
robster94gt said: Hey all, I've seen a lot of topics on the MACH 460, but haven't seen anything about retaining the stock speakers with aftermarket amps. Here's my situation- I recently installed ... Read more >>
July 13, 2022 * 10 posts * 164 views
Adfalenski said: O2 Spenser's need to be close enough to the engine to heat up. Read more >>
July 13, 2022 * 3 posts * 18 views
Sn95 matt said: so i have discovered a issue with my car once again so I'm starting to think my running cammed issue is due to electrical/distributor problems i was watching a video of a guy diagnosing ... Read more >>
July 12, 2022 * 3 posts * 21 views
That Mustang Guy said: I have been asked this question a lot lately and noticed when Googled you don't get a quick and accurate answer. Here is an accurate guide. Hope this helps. [image] Read more >>
July 13, 2022 * 2 posts * 43 views
Adfalenski said: These are some bypass harnesses to look at: Scosche FD15B Compatible with 1995-97 Ford Premium System Amp-Bypass Jumper harness; At amp location Metra 70-5513 Radio Wiring Harness ... Read more >>
July 12, 2022 * 2 posts * 42 views
afield00 said: I have them, bought them used, 56cc version but had them decked slightly just to clean up. I wasn't confident they had the 8019 springs installed or the age so I replaced with ... Read more >>
July 12, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts need help July 12, 2022 * 10 posts * 92 views 94-95 5.0 - Specific Mach 460 - Plug and Play speaker upgrades? July 11, 2022 * 2 ... Read more >>
July 12, 2022 * 15 posts * 291 views
96blak54 said: Im sorry. Let me explain Take a good stanky cigar....may as well have some friends around sharing....take one of the vacuum lines and blow smoke into the engine while you all look ... Read more >>
Continue reading...
Srchop16
