Best Drag Racing Times
alex302
That sucks. Do you have a build thread?
Do not know just lost oil pressure on final pass and that was it. Motor didnt look that bad just as a oil starved motor would. What sucked was the crank took the beating from the heat.
miss.mod.50
Central IL
Hmm...last time 02 was at the track.......i have the 12.3 pass on video, later in the day i got a 12.1 (will get timeslip pic when I get home).
BBK CAI, Prof Products (junk) upper plenum, Comp XE268 cams, comp springs/retainers, NX 125 shot, lakewood 90/10 front, kyb 5 way rear, moroso rear drag springs, factory (ashamed to admit) cut front springs, Pypes o/r X, SLP cat-back with magnaflows (replaced the SLP LM1 bullets), and on rear prostars with MT's.
[video=youtube_share;uFD8QFmpdFY]http://youtu.be/uFD8QFmpdFY[/video]
Fastest I've gone in any car.....uhh get ready for the most inconsistant time slip you've ever seen......lets just say my first weekend in a low 7 second car took some getting used to.....had to let off at the 1/8 cuz I didnt have NHRA license at the time....but I still got in trouble for going too fast lol.
[video=youtube_share;3yud7KIdEK4]http://youtu.be/3yud7KIdEK4[/video]
Musturd
BBK CAI, Prof Products (junk) upper plenum, Comp XE268 cams, comp springs/retainers, NX 125 shot, Pypes o/r X, SLP cat-back with magnaflows (replaced the SLP LM1 bullets), and on MT's.
Thts bad ass girl :) <3
97Junkstang_cobra
Dont know where my slip is but in 09 I took my car to Darlington (I live near Bristol it's a little slower track) My 03 gt with a vortech v2 sq at 10 psi 412 rwhp/389 rwtq on 555r's got a 12.36 @ 114 mph of a 1.83 60'. Not fast but was a fun car reliable as hell.
Racsirx
I found some old pics of my 94 GT Convertible that I sold many years ago, it ran a best of 10.98 on a 150 shot and on motor the best I could get was 11.90, and it had a 331 10.5:1 compression, TFS heads, TFS intake, comp 274 cam, Lentech AODE and 4:10s
Racsirx
Here is a summary of my 88 Coupe, Keith Craft 306, 9:1 compression, stock block, stock cam retarded 4 degrees, 1.7 roller rockers, unported TFS Twisted Wedge Heads just with upgraded valve springs, ported GT40 lower manifold, Hogan sheet metal upper intake,Master Power T70, .81 housing, 14lbs of boost, Hallman boost controller, Accufab 75mm throttle body, 50lbs injectors, 255 intank fuel pump, 255 inline pump, stock fuel lines, SN95 fuel lines, stock computer with a SCT chip to adjust air/fuel, MSD coil, MSD 6AL, MSD two-step, timing locked at 24 degrees, C16 fuel, C4 with safety shield ,4500 stall, stock K-member, cut Moroso drag front springs, cut 4 cylinder rear springs, Wolfe upper & lower control arms, Wolfe anti-roll bar, Wolfe 10pt cage, Wolfe subframes, Jaz front drivers seat, no passenger seat, Factory seat belts removed, heater box removed, manual windows, removed the center console to install the B&M Pro Stick otherwise the interior looks untouched, no a/c, no power steering, manual rack, no front bumper support, no rear bumper, doors gutted, no fender liners, no widow wiper motor and the arms under the cowl, electric fan, underdrive pulleys, 130 AMP alternator, of course no smog pump, no horn, 28" Hoosier slicks, 3:55 gears with a spool, Lakewood 90/10s & 50/50s, Very Heavy Cervini 6" lift off hood, it made 531RWHP & 534RWTQ. 2750lbs without driver. I built this Coupe with spare parts that I had from other Mustangs, I wanted to build this Coupe to see how fast I can go with simple lower end parts and not look like a gutted car, but I did try to take everything off I could that no one would notice.
http://www.youtube.com/watch?v=RI2e2L4jP2o
60ft 1.461
1/8 6.402 @ 110.617 MPH
1/4 10.000 @ 138.984 MPH
UPDATED 11/21/09
60ft 1.467
1/8 6.321 @ 110.261 MPH
1/4 9.89 @ 141.084 MPH
UPDATED 12/5/09
Reaction .032
I1 60ft was working
I2 4.037
I3 6.236
MPH (I3) 113.072
I4 8.136
E.T. 9.758
MPH 142.051
KillNThrill24
Cleveland Ohio
Hell yeah^
I'm bumping this thread... Don't feel like finding my slips but second time out ever at the track went decent. Pulled a 14.0 at 93 with a 1.9. Only got 2 runs in so that sucked. The second run I just had all wrong from the start. From doing the burnout in first to not (I guess) having the shifter all the way into first and having that lovely grind so I got a +2 reaction lol. But hey I'm happy, I improved over 1 second from last year. And that 6k launch on slicks is like a freakin drug. I admit I'm more of a highway runner, but that was a lot of fun today. And I'm definitely hooked
Rice_slayer
Guess I should update mine, specs in sig, I ran an 11.91 as well but the slip is f*cked up, their printer printed the wrong everything except the ET -.-.
cameron57
Who has the fastest so far are motor swaps ok to post in here as long as its ford?
Addermk2
Looks like I'll have to beat 9.7 next year to take the #1 spot from the current lead holder.
v6mustang94
Gave drag racing a shot last Wed. night. Here's my best run:
14.955 @ 93 mph with a 2.277 60'
[video=youtube;QXbkRtOPHjc]https://www.youtube.com/watch?v=QXbkRtOPHjc[/video]
Motor is basically stock as I've been more focused on building a car for track days.
Relevant mods:
Catless cat-back, CAI, removed smog pump, 3.55 gears, advanced timing.
Springs, Shocks/Struts, SFCs, LCAs, removed rear seat, racing seats, 18" 275 NT05s
v6mustang94
I had a ton of fun. I just love to race no matter what it is. You learn so much more about your car when you're on the track (drag or road racing).
