Cams
Shawn 1980
Good morning, I'm planning on doing cams in my 1996 2v and have some questions, so it's a 1996 4.6 2v with PI heads and a turbo kit I built, bottom end is stock. I'm looking to put a set of cams mainly for the chop car is only running 5-8 psi boost nothing more and I'd like to avoid cutting pistons etc. I will be putting new valve springs and retainers. Looking for recommendations
Thanks.
98darkhorse.com
Charlotte North Carolina
I am running the Howards Rattler cams runs strong no issues with drivability. this cam allows for use of stock PI springs and retainers. plus it sounds different from other mustangs around me. not sure what is like with boost. you can hit up https://www.facebook.com/todd.warren.376 Todd Warren Cams, they do custom grind ordering for you.
here is the Idle clip
Shawn 1980
Shawn 1980
This is pretty much what I'm looking for thanks. Sounds good
96blak54
In the shop
Why would anyone spend the extra coin for "specd" cams when all the op wants is chop? Just buy off the shelf cams. Personally id call Ed Curtis
J_lope82
South Texas
I’m guess to reassure that there won’t be any valve to piston clash with his set up.
Snorky
I personally would call Jordan at MHS or Jim Cushman from CMS. Both are great to work with. Jordan changed some cam specs of his normal "shelf" cams for me for my turbo car.
bwiz760
