Congrats to our Febuary 2009 Winner....95Opal
Bought the car 4.5 years ago and purchased all the Bolton's the first day I owned it. Drove it with the gears, exhaust, pulleys, t-body & TFS intake, for about a year. That's when I first saw 69clarks car and decided to get serious with mine.
Being the car was bought out of NY it had the typical NY dings in every corner of each bumper cover. That's where the Saleen kit came in. I just didn't see it fit to replace factory parts with factory parts. It just didn't make sense to me and what better than a Saleen vert? Once I had all the body panels I sent the car to my painter to give it a full resto. I had him take out every single ding and repaint the entire car including jams and trunk area.
At this point the car looked sweet but was still rolling with the stock suspension and power plant. I drove it like this for a summer and then decided to do the motor, suspension and interior.
After looking at countless threads about engine bays, I had come up with a game plan. I again took the car to my body guy and went over everything I wanted done. After he was finished with the bay It was time for the motor to go back in. Only this time it was a fresh cobra block with AFR heads. custom FTI cam and Holley intake. Once the motor was in I spent numerous hours detailing every part that went in the bay paying close attention to the way it flowed with the rest of the engine. I'm talking right down to the bolts being used.
69clark was a great help in this department as I made him look at hundreds of pics of my bay to pick out any small detail that jumped out at him. When something didn't look as though it fit it was replaced.
I also redid the stock suspension with all Maximum Motorsports and Steeda stuff.
I also pulled the gut out to revamp the interior a bit. I deleted the rear seat to make room for the nitrous set up and added fresh carpet, new Corbeau seats, autometer guages and a few custom dash pieces.
As of now the car is driven on nice weekends and to shows otherwise she sits in her home and awaits her next beating. I still,have a few tricks up my sleeve to finish this baby off but for now the plans are on hold. Maybe next winter I can finally wrap this project up and move on to the next.
95GT Opal Frost
ENGINE:
Afr165s heads w/ PS3 spring upgrade
FTI custom cam
Vinton valve seals
Comp cams 1.6 rockers
Holley systemax2 intake
3/8" intake spacer
TFS intake elbow
70mm FRPP tb
95mm P-mas MAF
30#FRPP injectors
BBRC billet aluminum fuel rails
Braided fuel line
Aeromotive A1000 platinum regulator
10.5 Livewire plug wires
Livewire Billet wire seperators
4" polished CAI
K&N filter
Billet Idler and power steering pulleys
Billet smog pump eliminator pulley
Billet Pi-thon hose locks
Custom billet coil cover
A/C delete
Fluidyne aluminum radiator
UPR polished radiator cover
Stewart stage 1 water pump
AFM polished valve covers
150 amp polished ALT
ASP billet under drive pulleys
Pioneer SFI balancer
Energy suspension motor mounts
Mac chrome radiator hose kit
Mac headers
Mac off-road H
Bassani catback
MSD 6al and coil
Walbro 255lph pump
Morosso overflow tank
Zitronics wideband
SCT 4 bank chip
Zex 125 wet shot
Nitrous Express gen x kit
Zex traction control unit
Zex dual purge kit
DRIVETRAIN:
FRPP 4.10s
Pro 5.0 shifter
Super King cobra clutch
FRPP billet steel flywheel
FRPP aluminum drive shaft
T/A Performance girdle
Energy suspension crossmember bushings
SUSPENSION AND BRAKES:
Steeda aluminum lower control arms
FRPP upper control arms
Eibach Pro kit
Tokico shocks and struts
Steed bumpsteer kit
Steeda STB
Steeda end links
Steeda front and rear sways
MM subs
MM aluminum rack bushings
MM steering shaft
MM caster camber plates
Comp engineering adj. pinion snubber
Cobra brakes frnt and rear
Drilled and slotted rotors
stainless lines
EXTERIOR AND INTERIOR
Saleen s281 bodykit
Saleen heat extractor hood
Saleen s281 wing
Saleen speedster cover
Saleen lightbar
Saleen 18" replica wheels
Saleen windscreen
BFG KDW2 rubber
Rear seat delete
Bullitt pedals
Bullitt shifter bezel
03 cobra shift nob
Corbeau GTS2 seats
Auotometer ultralite triple A pillar guages(water.oil,volts)
Autometer ultralite nitrous pressure guage
Autometer AF guage
White face gauges
Custom instrument cluster bezels
Custom billet sill plates
95GT Opal Frost
ENGINE:
FTI custom cam
Vinton valve seals
3/8" intake spacer
TFS intake elbow
70mm FRPP tb
95mm P-mas MAF
30#FRPP injectors
Braided fuel line
4" polished CAI
K&N filter
A/C delete
Mac headers
Mac off-road H
Bassani catback
MSD 6al and coil
Walbro 255lph pump
Zitronics wideband
SCT 4 bank chip
Zex 125 wet shot
Zex dual purge kit
DRIVETRAIN:
FRPP 4.10s
Pro 5.0 shifter
Eibach Pro kit
Steed bumpsteer kit
Steeda STB
Steeda end links
MM subs
MM steering shaft
stainless lines
Saleen s281 bodykit
Saleen s281 wing
Saleen lightbar
Saleen windscreen
BFG KDW2 rubber
Rear seat delete
Bullitt pedals
03 cobra shift nob
Corbeau GTS2 seats
Autometer AF guage
White face gauges
