Tillerman77
Many folks have had misfire issues with the Ford Racing wires. OEM Motorcraft wires are a solid replacement option if you don't find the misfire elsewhere. BTW, my 97 Cobra developed a misfire which was due to the same kind of damage on the wire as you are describing. Nothing was visible at night, but replacing the wires with new Motorcraft wires and fresh plugs solved my issue.Ford Racing 9mm wires and yes the misfire was present before I bought these. One of the wires that was on car when I brought it had a damaged area on the silicone insulation. It didn't appear to be all the way into the inner core but not knowing if this damaged area could be enabling a crossfire I used some silicone adhesive to patch the spot. The mis fire remained so I replaced the wires. I did observe the damaged wire at night with engine running to see if a crossfire was present and didn't notice any
