Headers for 225
brian95
indiana
I am switching to new heads for my 363 and I’m using the TFS-225 R heads. I have Mac 1 3/4 long tunes with 3 inch collector on my tfs t/w now but they don’t seam like they are going to fit. I matched it with the gasket. Does anyone know who makes them for sn95 with out going custom. And if custom is the way then who?
evilcw311
Most Evil Member!
Louisville, KY
You have to search for those who make tf friendly headers. Unfortunately most standard off the shelf headers won’t cause of the high port design.
Pretty sure you need a set that’s 1 5/8’s as well
castine917
wyoming, mi
Which bolt pattern? 2,3, or staggered?
What about the gasket makes you think they won't fit?
If they fit the car but not head you may just want to look in to adapter plate.
Randall Garner
US NAVY
I went to DDauto.com. They deal with fox and sn95 builds for racing. I have a set of high ports on a 351w swapped into a SN95. Had only 1 tube thT was even close. To being tight. They make long and mid length. Depending on your needs. 1 3/4 primary should be ok. Are you using the felpro 1487 header gasket to ensure fit
stillridin
