Highlighted posts from Friday, Apr. 08, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
April 07, 2022 * 20 posts * 157 views
ttocs said: yea I never had a problem scraping anything in my 94 when I was in indiana with it. When I moved to AZ funny enough even though its the desert when it rains there it REALLY rains ... Read more >>
April 07, 2022 * 13 posts * 94 views
cryptospook said: Honestly, not sure. I bought it recently and it's in roooooough shape. ODO says 131140 miles, but idk (does the odo still track mileage when it's dimmed out(needs solder joint ... Read more >>
April 08, 2022 * 8 posts * 30 views
SouthernGorilla said: Being completely new to the Mustang world I have no clue what parts/brands to go for or avoid. So I'm turning to my newly adopted family for guidance. I need new shocks/struts. ... Read more >>
April 07, 2022 * 25 posts * 176 views
ttocs said: ID is one of those brands I have just never had a complaint about. I sold them back in the 90s(when I was lucky people were to cheap here most of the time) and you could always ... Read more >>
April 07, 2022 * 19 posts * 198 views
ttocs said: ever check the fuel pressure? Cutting out at high rpm's makes me wonder assuming all the electrical connections are still good. If you have any sensors that the harness has 2 clips ... Read more >>
April 07, 2022 * 1 post * 11 views
RockAuto said: 5% Discount Code: 92870C645C1C62 Expires: July 7, 2022 Please enter this code in the 'How Did You Hear About Us' box to receive the discount. Please enter ONLY the discount code, ... Read more >>
April 07, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Replaced speedo gear; still no speedo/odo April 06, 2022 * 11 posts * 59 views 94-95 5.0 - Specific Identity crisis April 06, 2022 ... Read more >>
April 07, 2022 * 11 posts * 122 views
cryptospook said: So, I installed them, seem to fit fine, certainly looks more even than a lowering spring in the rear and a stock spring in the front. Not sure if they aren't a bit taller than ... Read more >>
April 07, 2022 * 37 posts * 456 views
joemomma said: Yes the GT40/P are cast iron. Those springs will support a pretty aggressive cam if you should decide to go that way. Just something to think about here - you're looking at close ... Read more >>
Continue reading...
RevJon
