Highlighted posts from Saturday, Oct. 08, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
October 05, 2022 * 17 posts * 128 views
lwarrior1016 said: Terminator also only has 4 I/O. Dominator is the all out ecu. But yes they still have the terminator, hp, and dominator. You're going to live the Holley. They work really well, ... Read more >>
October 06, 2022 * 5 posts * 48 views
LEGALLYFAST said: Looking for those have gone those routes, any regrets? The 363 is easy I get it. Anyone got the 427 regretted that? In line to get a short block, trying to make up my mind if I ... Read more >>
October 05, 2022 * 11 posts * 180 views
RAU03MACH said: hopefully the gaskets were put on correctly and none of the water outlets were blocked and thats hard to tell because the heads are installed seen that mistake many times Read more >>
October 06, 2022 * 3 posts * 41 views
97JF said: Does anyone know what this part does or what it's purpose for being there ? There's one in each of the rear wheel arches behind the rear tyres I noticed today when I took the rear ... Read more >>
October 07, 2022 * 2 posts * 27 views
JPuehl said: I have a '01 Cobra and do not like the "partial" side scoops and would love to replace them with the "full" scoops but trying to figure out if there's a definitive model of the ... Read more >>
October 04, 2022 * 7 posts * 103 views
302hobronco said: OK so pulled the shifter out and put the plastic shift retaining cup in. Rattle in 3rd and 4th under load still there. It isn't as loud but it is still there. The Trans has 144k ... Read more >>
October 04, 2022 * 3 posts * 62 views
NEURON said: Mine has tags on them, but bad weather could eradicate them. Easy to replace on the back though. I would just get some new ones. Read more >>
October 07, 2022 * 1 post * 9 views
NicksGTR said: I just purchased a used set of Ford green top 42lb injectors and would like to send them out to be cleaned and tested. Any recommendations out there for this service? Read more >>
October 07, 2022 * 1 post * 8 views
Top Flight Automotive said: [image] *Expires 10/13/22. Promotional Discounts are applied to List Prices and cannot be combined with other offers. Some restrictions apply. The maximum allowable discount on ... Read more >>
October 06, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts EFI Stand Alone V6 October 05, 2022 * 17 posts * 81 views 94-04 - V6 Specific New project and 2 questions October 05, 2022 * 11 ... Read more >>
Continue reading...
Superman3872
