SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
October 09, 2022 * 11 posts * 66 views
lwarrior1016 said: This was my 12:1 compression 2 valve with big comp cams. Ebay long tubes, home made h pipe, and MAC irs catback. [link] Read more >>
October 08, 2022 * 9 posts * 91 views
Randall Garner said: Why not consider the 331 or. 347 if your wanting to stay with the 8.2 block. But again the the 351w strokers are much stronger can use a OEM block. I've seen 408's spin 7500 all ... Read more >>
October 09, 2022 * 4 posts * 34 views
white95 said: One of our west coast members just had a set sent off and cleaned. He was pleased with the service. @ReplicaR - Where did you send yours to be cleaned recently? Read more >>
October 09, 2022 * 3 posts * 69 views
white95 said: The area could be removed from a wrecked vehicle and possibly grafted into yours. Read more >>
October 09, 2022 * 1 post * 13 views
Exhausts
Tripp said: Hello, This is my first check engine light I've gotten since I bought my car. It reads Ive gathered this is Bank 2 (Left side) Sensor 1 (Before cat) Does anyone know where this ... Read more >>
October 09, 2022 * 1 post * 14 views
SN95Newsletter said: Click here to view on the web Highlighted posts EFI Stand Alone V6 October 05, 2022 * 17 posts * 128 views 94-04 - V6 Specific 363 or 427? October 06, 2022 * 5 posts * 48 views ... Read more >>
October 08, 2022 * 7 posts * 140 views
Warhorse Racing said: One of my favorite things about autocross is that the courses are always different. At this event, the course designer used the art of deception to try to slow drivers down. I ... Read more >>
October 08, 2022 * 27 posts * 645 views
weendoggy said: I did mine with stock gauges and it works. Depending on what Gen-version you're using dictates the wiring needs, but all doable. If you want to change the dash, you can get the ... Read more >>
Continue reading...
