Highlighted posts from Sunday, Oct. 23, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
October 22, 2022 * 11 posts * 58 views
Snorky said: I see what you mean, yeah this top doesn't look original and the seals and everything arent dry rotted or anything. Just from my inexperienced convertible perspective looks incomplete. ... Read more >>
October 22, 2022 * 17 posts * 137 views
Billy77 said: I have to correct myself: there is a weep hole on top of the waterpump. It's the indicator that when coolant comes out, the seal has failed. A mechanic mentioned to spray some ... Read more >>
October 22, 2022 * 6 posts * 52 views
ttocs said: I just did the t56 magnum and now that the check is written and it is installed I have no regrets. It took a little bit of work to get in and now one likes writing those checks ... Read more >>
October 22, 2022 * 3 posts * 24 views
triggersnob said: Recently did the 3g alternator upgrade but every know and then I still get a massive voltage drop at idle that if I let it will stall the car, I'm thinking iac or pcv, any help ... Read more >>
October 23, 2022 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts Strange noise during idle October 19, 2022 * 12 posts * 109 views 96-04 - 2V Specific Is Kenne Bell returning? October 19, 2022 ... Read more >>
October 22, 2022 * 4 posts * 59 views
Daryl said: Supposed to get it back early next week; Monday or Tuesday. Couple of other jobs jumped ahead of me while they were waiting for the clutch to arrive. Here's what the clutch kit ... Read more >>
October 22, 2022 * 11 posts * 223 views
tmwsccsh said: Mine does this a fair bit. I punch the door card where the motor is and it pings back to life for a month or so. Seriously... TMW Read more >>
October 22, 2022 * 37 posts * 397 views
dwcopple said: Changed it, didn't work. Guy at Ford said it's usually the vapor solenoid on the charcoal canister gets stuck and needs replacement. Guess I'll try that next for $58 more bucks. ... Read more >>
October 22, 2022 * 22 posts * 604 views
triggersnob said: I just did the 3g on mine for the 2nd time,, the first one failed as well, know it's finally charging but when I put on the ac and cone to a stop at random I will get a surge that ... Read more >>
October 22, 2022 * 31 posts * 938 views
BHernandez said: Well if you get close to redline and that same rattle, it's definitely a thrust bearing. Read more >>
Continue reading...
Brad Nimbus
