Highlighted posts from Sunday, Oct. 30, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
October 29, 2022 * 32 posts * 307 views
waynenorcross said: Try Jim at Performancepartsinc.com. tell him Wayne sent you. He carries a lot of odds and ends not on his website and has connections back at Ford. Read more >>
October 29, 2022 * 16 posts * 132 views
Pallgor said: Sounds like there's an air pocket. Common problem with todays motors. That's why we use a pressurized coolant system to refill radiators at the shop Read more >>
October 29, 2022 * 5 posts * 24 views
J_lope82 said: I am wondering if installing a aftermarket adjustable fuel pressure regulator would add a little more horsepower? Or what benefits I would get with installing one? Current mods ... Read more >>
October 29, 2022 * 2 posts * 19 views
Pallgor said: ABS light came on my 96 GT I haven't scanned it yet but I was just wondering what is the most common reason for why. 4.6 5speed 91,000 miles Ty Read more >>
October 29, 2022 * 2 posts * 31 views
95opal said: Not sure what hp level your shooting for but 80s should be good 750 800 hp. You want your regulator after the rails. As for the lines you can run them either to the back of one ... Read more >>
October 30, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts 96-04 - 2V Specific October 29, 2022 * 31 posts * 259 views 96-04 - 2V Specific 94-04 - V6 Specific October 28, 2022 * 13 posts ... Read more >>
October 29, 2022 * 14 posts * 128 views
Pallgor said: Trans is filled. Used a old piece of rubber fuel line. It took 3 & 3/4 qts to fill. Shifts better but may need new synchros down the line but good for now Thanks for all the suggestions Read more >>
October 29, 2022 * 12 posts * 158 views
lwarrior1016 said: Then you definitely have a t45. The t5 came in the v6 cars and the pushrod 5.0 cars, the t5 also has a detachable bell housing. The t45 has the modular bell pattern and the t5 ... Read more >>
October 30, 2022 * 28 posts * 754 views
Drw814 said: I do agree that it is an exhaust issue. In the picture here you can see the sway bar position with the car on jacks. With the car on the ground, the sway bar will both move up ... Read more >>
October 30, 2022 * 26 posts * 1,020 views
Randall Garner said: If all these troubleshooting actions are still a no go on fixing the overheating, as your heads heat up things expand. And you may have a valve seat or guide issue. Or you may ... Read more >>
Continue reading...
Superman3872
